Author Topic: Lowering PixInsight.exe priority on Windows with config option  (Read 2630 times)
Offline astrospotter
Having some trouble locating (if it exists) an option to always try to have PixInsight.exe run with windows 7  priority 'Below Normal'.
This is very important when you want to chug away on 100 frames that need calibration but you also 'have a life' and want to use your pc for other things at higher priority.
Is there such a 'always run PixInsight.exe at below normal' priority option or perhaps I should make my shortcut do this with a native windows exe startup option?
So far I bring up task manager and set it manually but that is getting a bit old.
Mark
Offline NKV
Re: Lowering PixInsight.exe priority on Windows with config option
« Reply #1 on: 2012 September 26 21:10:42 »
Menu>Edit>GlobalPreferences>ParalellProcessing  ;)
« Reply #2 on: 2013 February 18 15:43:51 »
As followup I have found that a very effective way to not have PI steel all my other activity cpu cycles is to set max processors.  For my quad core with hyperthread I set this value to 6.
I gave up on trying to set PI to use 'Below Normal' priority which is a windows term as that yielded not much of the desired effect.   I just leave a few (hyperthread) cores open and that does it nicely.
Now I can do huge batch processing and still get along with (mundane) other tasks outside of PI.
