Author Topic: Batch Processing and Mountain Lion  (Read 3449 times)
Offline Jack Harvey
« on: 2012 September 24 16:12:16 »
First time trying to use Batch Processing after loading OSX Mtn Lion.  The script runs fine but then will not shut down.  PI freezes and when you try to quit PI what reamins is the Batch Processing GUI and on top of that is a rapidly flashing  window (Do you really want to exit Batch Processing).  I have found no way other than to shut down my computer to stop this iteration.
Did find a way to work around.  After the script runs you select the exit button in the lower right.  Any other way to terminate the script seem to give the above issue.
« Last Edit: 2012 September 24 16:25:23 by Jack Harvey »
Jack Harvey, PTeam Member
