Author Topic: September 2012 Contest Images  (Read 16477 times)
Offline Javio
  • Moderator
    • PixInsight
« on: 2012 September 06 19:18:09 »
The September edition of the 2012 PixInsight Monthly Astrophotography Contest is open. Check the contest rules and send your images until September 20th. Please use this post ONLY to submit your images.
Good luck!
Javier Sanchis Muñoz
Offline Ignacio
    • PampaSkies
Re: September 2012 Contest Images
« Reply #1 on: 2012 September 12 13:14:54 »
Barlowed M16 from the suburbs
IMAGING DATA
Optical train: AP130 EDF GT + AP 2x Barlow + IDAS LPS2 filter
Mount: Losmandy G11
Guiding: B&L 80/800 SCT guidescope + Lifecam Cinema + PHD
Camera: Canon 1000D (modded and peltier cooled)
Frames: 55 lights, 5 min. ea. @iso800, calibrated with 50 darks, 30 flats and 30 bias frames
Processing: data reduction and post processing in Pixinsight 1.7, minor adjustments in Canon Digital Photo Professional
Date: 2012-07-24
Place: General Pacheco, Buenos Aires, Argentina
Seeing & transparency: very good/good (suburban skies)
Ignacio
« Last Edit: 2012 September 21 09:00:43 by idiaz »
Offline starhopper
    • starhopper
Re: September 2012 Contest Images ...my first image post here at all
« Reply #2 on: 2012 September 14 14:08:05 »
NGC7000 in Ha RGB
Data:
Title: NGC7000 Area
Optic: Canon EF200f2.8 at f/2.8
Filter: Baader 50mm HaRGB
Camera: SBIG STL11000M C2 at -18°C, selfguiding
Exposures: Ha 10x8min, 17x Darks; RGB 14:14:14min, subexposure 2min, 10x Darks, 31x Bias, 27x Flats
Date: 9.09.2012, bad condition (transparency and clouds)
Processing:
ImageCalibration/Integration, StarAlignment, Stacking: avgSigma for RGB & Winsorized for Ha, RGB Combination, Silvercups HaRGB Script, ColorSaturation, DBE, Histogramm Streching
Processing Notes:
I am new in PI, so processing is always a challenge for me. StarAlignments log says: failed=0 but my blue images were not aligned properly. The solution was to give a 2 in HotPixelRemoval. Next I had trouble with the Auto Pixel interpolation in StarAlignment, stars in my RGB frames got dark pixels around (clamping threshold used). The solution was to give a BicubicSpline Interpolation. My 200mm telephoto lens led to undersampled frames, this may be the cause.
Than I tried to make a L-RGB Image but all stars lost their colors, so I decided to continue with RGB combination (I made L-RGB images successfully in PI with other data). After that I decided to reduce starsize in the blue channel (caused by the lens). Than the use of silvercups HaRGB script was true fun. I like it. It works fine, despite the issue with applied STF.
Altogether I am very satisfied with the result and I hope you like it too.
Thomas Jaeger - www.starhopper.de
Thomas Jäger
https://www.starhopper.eu
12"f/3.8 & 8"f/2.9 Astrograph
SBIG STL11000M, Moravian G2 8300
Vixen Atlux Mount, Skywatcher AZ-EQ6 GT
Skywatcher Esprit 100/550
Offline melvov
« Reply #3 on: 2012 September 19 05:04:03 »
Sadr Region in Cygnus:
HaRGB (DSLR) image
Processed in PixInsight
More details at
http://www.astrobin.com/19677/B/?mod=
Offline Philippe B.
    • CIEL AUSTRAL
« Reply #4 on: 2012 September 20 00:01:39 »
Here is Sharpless 119
Takahashi FSQ106ED f/3.6 at 395mm focale length, QSI540WSG with Ha 3nm
Exposure time : 10x20min
Preprocessing : Pixinsight with my optimized process icons
Processing :
- denoising by ATWT
- Histogram Transform
- HDRMT 7 scales 4 iterations
- Curve transform
- Grey to RGB and ICC profil
That's all !
Format 100% when clicking on it :
Offline Oleg Bryzgalov
    • My astrophotosight (in Russian, sorry)
« Reply #5 on: 2012 September 20 06:55:02 »
Nebula NGC7129 and  open cluster NGC7142 in Cepheus
This picture was photographed during seven nights, in august-september 2012 in Khlepcha observatory, Ukraine.
Equipment: reflector S&D 254 mm. f/4.7
Mount WhiteSwan-180, camera QSI-583wsg, Tevevue Paracorr-2. Off-axis guidecamera Orion SSAG.
LRGB filter set Baader Planetarium.
L=57*600 sec. RGB: 21*900 sec. each channel. All unbinned.
Processed Pixinsight 1.7
Full size picture: http://olegbr.astroclub.kiev.ua/files/astrofoto/NGC7129_42/NGC7129_NGC7142_LRGB_Oleg_Bryzgalov.jpg
Sincerely, Oleg.
