Author Topic: Executing a sequence of steps across multiple images  (Read 3646 times)
Offline slang
« on: 2012 September 05 03:21:01 »
Hi.
I've got a series of images - well, ~200 lunar eclipse images of which I need ~80 or so to be used. The basic initial pre-processing is the same, crop, histogram etc. Whilst I can create process icons, and drag and drop these onto each open image, this presents the following problem;
1) If I load all 80 images at once, the swap space goes a bit nuts, and the system slows down somewhat (only 8GByte of RAM)
2) It really is tedious applying process icon 1 to 80 images, then process icon 2 etc. etc. etc.
I have searched and checked as much as I can, but not seen an answer. Is there a tool/script/utility that I can use to apply a single process icon (or even better, several of them) to a number of images, either already open, or on disk.
Apologies if this is in the wrong forum - been a while since I've posted anything...
Cheers -
Mounts: Orion Atlas 10 eq-g, Explore Scientific G11-PMC8
Scopes: GSO RC8, Astrophysics CCDT67, ES FCD100-80, TSFLAT2
Guiding: ST80/QHY OAG/QHY5L-II-M
Cameras: Canon EOS 450D (IR Mod), QHY8L, QHY163m/QHYFW2-US/Astronomik LRGBHaSiiOii
Offline Ioannis Ioannou
Re: Executing a sequence of steps across multiple images
« Reply #1 on: 2012 September 05 03:38:05 »
Do you know about Image Container ? It does exactly what you want, put the images, trim the parameters regarding the output of the results, save an instance on the desktop, drag any process (even a process container I think) over it. I'm doing this a lot of times for batch processes on many images.
Clear Skies
John (Ioannis)
FSQ106N+Robofocus+QHY-22+SX USB wheel+Baader filters
SX OAG+DSI Pro guiding a NEQ6
PI for the rest :)
Offline slang
« Reply #2 on: 2012 September 05 04:10:53 »
Ahhh, WOW, thanx.
Had heard about ImageContainers, but didn't remember enough detail to apply it to my situation. Indeed, it is what I need.
By following http://www.astrosurf.com/astronosur/pixinsight/image-container-1.htm or the translated
http://translate.google.com/translate?sl=auto&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fwww.astrosurf.com%2Fastronosur%2Fpixinsight%2Fimage-container-1.htm
I have all the answers that I need. Thank you (and of course all the PI devs and contributors) for saving a LOT of my time.
Cheers -
