Author Topic: deconvolution- success?  (Read 2421 times)
Offline astrodoc71
« on: 2012 September 03 08:12:04 »
I'm processing an image of M13. 1st time using PI. I noticed when using either deconvolution or morphologic transformation and a basic star mask, I could not see a darn thing happening. I used the mask first with default settings and then changed them a bit. I think maybe in MT I saw a slight star shrinking but very little. I then took the mask totally off and did a 50 iteration deconvolution and got a pretty smooth sharpening effect with no significant artifacts?! I don't see any ringing to speak of or anything else. I mean it looks pretty good to me. So I guess I'm surprised that it came out as clean as it did with no mask? Interestingly, after deconvolving I went back to MT and using the mask with 1 iteration it actually showed more of a change (for the better) than it did on the raw image? Perhaps it's the nature of the object then? Just curious
Offline Warhen
    • Billions and Billions
Re: deconvolution- success?
« Reply #1 on: 2012 October 29 21:49:59 »
Hey Doc, In the spirit of covering all our bases, you're making sure that elements you want affected by a change are revealed by white in the mask? If not, just invert the mask to conceal w/ black what you don't want affected. If this isn't the issue, I'm surprised as you were the decon yielded a good result. It generally takes a deringing support star mask, a range or luminance mask to protect desired areas and the dialing in of some rather specific settings to not end up with goulash! ;) Also, Decon is appropos for linear stages, while I'd reserve Morphological for after nonlinear stretches. Let us know more.
Best always, Warren
Warren A. Keller
www.ip4ap.com
