Author Topic: matching star or nebulosity intensity between RGB and NB filters  (Read 2634 times)
Offline troypiggo
Say I have 2 images of the same nebula target, same gear, one taken with a broadband red filter, the other narrowband Ha.  The stars and continuum objects are brighter in the R filter, but the nebulosity S/N ratio of the Ha is better.
I'm trying to figure out how to:
- match the star brighness in each image, so the stars look the same but nebulosity is stronger in the Ha one
- match the nebulosity brightness in each, with the dimmer stars being in the Ha one
Any ideas?  Could just eye-ball it with histro-trans, but figure there's a more mathmatical/scientific way with PI as there usually is.
I'm getting back to working through http://pixinsight.com/tutorials/narrowband/theory/en.html and in there, the nebulosity is same brightness but Ha has weaker stars.
Offline xiaolingfeilu
Hello there and could I know if you have found a way to do it? Could I have some help here. I have got two imagines here and I would to adjust them into the same intensity and do you have any deal to do so?
Thank you
Best Wishes
Offline lucchett
Linear fit can help you achieving similar brightness: that can be useful in blending but ha-rgb is a big territory.
There are several threads that contains bits of information on the subject, a very good processing example by Vicent and a script distributed with PI.
I have found this recent thread very interesting:
http://pixinsight.com/forum/index.php?topic=7330.msg49230#msg49230
Andrea
