Author Topic: PixInsight 1.8 — Codename "Ripley"  (Read 48344 times)
Re: PixInsight 1.8 — Codename "Ripley"
« Reply #60 on: 2013 January 19 08:12:42 »
He has a very comfortable cell. Even with a chair.
Dungeons are not what they used to be...
Offline lromero
« Reply #61 on: 2013 January 24 01:50:35 »
Wonderful news, I am expecting to install to play with it.
Lluís Romero.
[url]www.astrosirius.org
[url]http://www.flickr.com/photos/66966766@N05/
Offline lucant
« Reply #62 on: 2013 January 29 08:51:05 »
I just installed new version on win7-32 host.
Yes, I know that 32bit is obsolete, but all worked well until I received message about some new updates (dll modules).
I agreed with installation, but after restart I receive an error message and I lost 3 processes, one of those very important: image registration.
I had to go back to default first install.
In attach 3 incompatible modules from update message.
What's wrong?
Regards
« Reply #63 on: 2013 January 29 14:15:18 »
Are you using version 1.8.0 RC1? If so, please install version 1.8.0 RC3, which we have released a few days ago. We have released these updates for 32-bit Windows, and AFAIK they work correctly.
Let me know if this solves the problem.
Offline lucant
« Reply #64 on: 2013 January 30 03:59:04 »
OK! Everything works well.
It was my own mistake  :sad:
I downloaded RC3 few days ago but installed RC1 again....
Many thanks
Lucio
Offline gvanhau
« Reply #65 on: 2013 January 31 04:15:00 »
Hello
Last night I instaled PI 1.8 RC3.
Until now every thing seems ok.
Several processes seem to be a lot faster than before (win 7 64bit).
Thanks for the huge effort.
Regards
Geert
Geert Vanhauwaert
Offline bretm
« Reply #66 on: 2013 February 03 09:45:02 »
I installed the latest version yesterday and then installed all the upgrades it recommended - it claims to be version 1.08.00.0963, and I think it has a memory leak in the registration process.
I am building a 3 panel mosaic, with about 1250 images per panel, and I started 3 instances of PI running because the registration processes doesn't seem to be very parallel, and I have enough cores and memory (and not enough patience :-)  to run multiple registrations at once.
It was running fine when I went to bed, but this morning, instead of being done they are all almost frozen -- occasionally it shows some activity on the console, but it is very slow, and each of the process has grown to about 12.5GB, and they are each using about 1/2 of 1 CPU core.
I saw this once before, but didn't report it here, so it seems to be reproducible, although it takes a while to make happen.
I've attached a directory listing sorted by date/time.  You can see the time between images growing.
Bret
« Last Edit: 2013 February 03 10:45:42 by bretm »
Offline jeffweiss9
« Reply #67 on: 2013 February 20 20:23:33 »
Some questions:
1) Is there an estimated date for the full release of 1.8 ?  (hard to follow this long thread without clear announcements)
2) Is the rumor I heard true that 1.8 will not support XP 32bit machines?
-Jeff
« Reply #68 on: 2013 February 20 20:34:49 »
The 32b thing is not a rumor. It has been announced here.
Offline Geoff
« Reply #69 on: 2013 February 20 22:19:30 »
In http://pixinsight.com/forum/index.php?topic=4401.0 to be precise
Don't panic! (Douglas Adams)
« Reply #70 on: 2013 February 20 22:21:21 »
