Author Topic: Tools for Planning a Mosaic?  (Read 3129 times)
Offline twade
« on: 2012 July 27 07:55:43 »
To all,
In the past I've used TheSky 6 or X for planning my mosaics; however, when using the center points of the frames, I get substantial rotation which leads to "holes" in the mosaic.  For example, I'm currently working on a two frame mosaic I took of the North America Nebula and the Gamma Cygnus region.  I used a 200mm lens and  a modified 5D2 camera. Comparing both frames, the position angle (PA) matches to within 30 arc minutes.  I thought this should be close enough, but when combining them, they have a rotational angle of 6 degrees which has left one side of the mosaic unusable.  Obviously, TheSky does not compensate for the rotational angles (i.e., it just gives the same PA for both frames).  As a result of this weakness, I'm looking for software or a way to plan my mosaics so I get excellent frame to frame matches.  What software do you use or how do you plan your mosaics?
Wade
Offline chris.bailey
Re: Tools for Planning a Mosaic?
« Reply #1 on: 2012 July 29 02:12:38 »
Have you asked the question on the Bisque forums? I have found it works very well but have never tried it at wide FOV. Have you tried increasing the overlap?
Offline twade
« Reply #2 on: 2012 July 30 08:29:58 »
Chris,
I have not.  I will give it a shot.
I could go 15 percent, but I would rather solve the rotation problem.  In all likelihood, I'll have to create my mosaics from wide-field shots to compensate for the true sky.  I believe Rob Gendler does it this way.
Wade
Offline ChristerS
« Reply #3 on: 2017 March 10 12:04:38 »
Notised also a rotaion at wide field at high altitudes with The Sky X but this must be a fact from spherical geometry as at dec=0 there was no rotation, and the software cant compensate for the rotation if there is no field rotator avaliable.
BR,
/Christer
Offline RickS
« Reply #4 on: 2017 March 10 18:06:46 »
I haven't tried it yet, but PI includes a MosaicPlanner script.
