Author Topic: Question about calibration  (Read 2609 times)
Offline gvanhau
« on: 2012 July 26 13:38:04 »
Hello
I was last night "playing" with some images taken with my QHY8L cam.
I got a strange behavior when calibrating:
If I only calibrate the images with flat frames to reduce vigneting and clean some dust particles, the resulting image resulted in a over correted one. The original darker corners an dust particles where now brighter than the rest of the image.
Curiously, I did then a try adding darks to the calibration process, and magic, the resulting frame was now evenly iluminated???
Can someone explain me why this can happen?
Regards
Geert
Geert Vanhauwaert
Offline Geoff
Re: Question about calibration
« Reply #1 on: 2012 July 26 15:34:45 »
Flat frames need a bias subtraction. Did you do this before applying them? If not, then the full calibration would have done this and hence the different result. Just a guess.
Don't panic! (Douglas Adams)
