Author Topic: Preprocessing Script Problem  (Read 2611 times)
Offline jeffweiss9
« on: 2012 July 17 13:48:22 »
Had no problem using the new preprocessing script twice now on luminosity data, but my first attempt at RGB caused the script to stop immediately saying that it couldn't find 2 second darks to calibrate my flats that happened to have 2 second exposure time?  I have no idea why that is happening since a minute before the same script successfully calibrated the luminosity lights using a similar set of 2 second flats without asking for any (nonexistent) 2-second darks.  Can anyone tell me what is going on?  It would seem it is really stopping for some other reason or perhaps cockpit error on my part.
 Thanks very much.
-Jeff
Offline jeffweiss9
Re: Preprocessing Script Problem
« Reply #1 on: 2012 July 17 21:29:44 »
Ok, here's some more detail on the problem and a work-around:
   I noticed that the MasterBias and MasterDark were listed in the script file boxes as "Binning 1" when they, like all the other frames were actually 2x2 binned. These two masters had been made by my former calibration method in PI that followed precisely Vicent's Calibration tutorial, as I had captured in a series of calibration process icons.  So those masters had previously been created by ImageIntegration, but for some reason the preprocessing script was calling them "Binning 1" instead of "Binning 2" as it had correctly classified all the other input files.  Not sure this was the same or yet a different problem than whatever caused it to look for 2-second dark frames to calibrate the flats above, but when I removed those two masters as inputs and replaced them with the original bias and darks frames used to make those masters (unchecking masters), the preprocessing script hummed away and worked just fine.
  It would seem there are a few loose ends here...
Thanks for taking a look.  And thanks for a great script that saves a lot of time.
Clear skies,
-Jeff
