Author Topic: When to Subtract Bias from Dark Frames  (Read 4134 times)
Offline MikeWiles
« on: 2012 July 10 13:12:55 »
Hi all,
Just looking for some clarification on the preferred process when creating master calibration frames.  I've used Vincent Peris' excellent tutorial to learn what little I know at this point.  I'm going through and truly studying it to gain a better understanding of the role of each calibration frame.  In regard to my specific question - it's a little unclear.
So my question - when is it best to subtract the bias from dark frames?  Should I create a master bias frame and then bias subtract each individual dark frame prior to integrating them into a master dark frame?  If I do it this way....then I presume that during the actual Image Calibration of a typical light frame that I would not want to check "Calibrate" under the Master Dark section, is that correct?
Or is it better to just do the integration of the master dark frame without bias subtracting each individual frame and then turn on the "Calibrate" checkbox during Image Calibration on the light frames and subtract it just once?  My sense is that it should be subtracted from each individual frame....but I wanted to ask here and further my understanding of the actual process.
Thanks in advance,
Offline Cleon_Wells
Re: When to Subtract Bias from Dark Frames
« Reply #1 on: 2012 July 10 17:23:10 »
Mike, I've had problems integrating calibrated Dark subs to create my MasterDark. Check this post out.
http://pixinsight.com/forum/index.php?topic=3663.msg25252#msg25252
Cleon
Offline Geoff
« Reply #2 on: 2012 July 10 18:39:17 »
The easiest way to calibrate is to use the batch preprocessing script.  Harry has a good video here http://www.harrysastroshed.com/preprocessing.html
Geoff
Don't panic! (Douglas Adams)
« Reply #3 on: 2012 July 10 19:16:21 »
Hola Mike.
I use master dark integrated without subtraction of bias and then use "Calibrate" during ImageCalibration to subtract masterbias.
Saludos. Alejandro.
Offline Ignacio
    • PampaSkies
« Reply #4 on: 2012 July 11 08:42:01 »
I prefer to do the bias calibration after building a master dark, to avoid negative numbers (clipping) when the dark signal is low (short subs and/or cooled cameras).
I understand that that is the way the  batch pre-processing script does it, right?
Ignacio
