If you're having trouble on Win32 platform with memory and ImageIntegration (II), I believe the workaround is to change the Buffer Size from 16MB to 1MB, and Stack Size from 1024MB to 100MB. This is pretty easy to do if you're manually using II, but if you're using the BPP script these variables are hard coded in the script.
The solution is to roll up your sleeves and manually edit the file. It's easy to do, it's just a plain text file. Using either Notepad or the inbuilt PI script editor, you want to edit the file BatchPreprocessing-engine.js. Around lines 1010 and 1011 you'll see this:
var II = new ImageIntegration;
II.inputHints = this.inputHints();
II.bufferSizeMB = 16;
II.stackSizeMB = 1024;
II.images = frameSet.enableTargetFrames( 2 );
You just need to change the 16 to 1, and 1024 to 100, then save the file and close, and restart PI.
II.bufferSizeMB = 1;
II.stackSizeMB = 100;
This is untested by me as I work on a 64bit Mac, but have a friend having trouble with BPP on his Win32 and am confident the above will help. Let me know if not or other solutions are available.
