Author Topic: Warning message from calibration  (Read 3376 times)
Offline LukeB
  • Live Long And Prosper
« on: 2012 July 08 06:46:29 »
I'm getting a warning message from the calibration process when it is writing the output files.
"** Warning: No correlation between the master dark and target frames."
Would someone be able to tell me what this means?
Thanks.
Luke
QSI583WS, QSI520ci, Loadstar Guide camera, Orion SSAG
GSO 250mm RC @F8, SW ED80, WS150 Acro
Orion SteadyStar AO
Paramount ME, EQ6
The Sky6, MaxImDL5 Pro, Starry Night Pro 6
PixInsight, ImagesPlus, Nebulosity, DeepSkyStacker
Offline Philip de Louraille
Re: Warning message from calibration
« Reply #1 on: 2012 July 08 07:32:34 »
Longer thread here: http://pixinsight.com/forum/index.php?topic=3783.msg25935#msg25935
Summary here:
"generally speaking, "no correlation between master dark and target frame" usually occurs when you are dealing with short subs and there is just not much dark signal there, either in the light or the dark. You'll probably find that you're getting this message on images taken with less than 60s exposures"
Philip de Louraille
Offline LukeB
« Reply #2 on: 2012 July 08 09:05:17 »
Hi Philip,
Both my master dark and subs are at 600 second exposure -25C.
I'm using a master bias master dark but no master light.
Interestingly, the warning does not occur on all subs, but yes for most.
The subject is M16 in narrow band. Lots of nebulosity.
Don't know if that means anything.
Thanks for the tip though.
Luke
Orion SteadyStar AO
Paramount ME, EQ6
Offline LukeB
« Reply #3 on: 2012 July 08 09:06:49 »
Sorry. That should have read
I'm using a master bias master dark but no master flat.
Luke
Hi Philip,
Luke
Orion SteadyStar AO
Paramount ME, EQ6
« Reply #4 on: 2012 July 08 10:56:22 »
Ok, perhaps this thread then: http://pixinsight.com/forum/index.php?topic=2803.0
Maybe a checkbox wasn't checked?
Note that you can perform searches in the forums by using the "Search" menu located on top, right below your name.
Philip de Louraille
