Author Topic: Background Neutralization  (Read 3863 times)
Offline Bob Hertel
« on: 2012 July 06 21:08:26 »
If for each color channel, I were to use the HistogramTransformation tool, and manually set the Midtones value to the median value for that channel, is the result equivalent to performing Background Neutralization?
Offline Philip de Louraille
Re: Background Neutralization
« Reply #1 on: 2012 July 06 21:14:40 »
I don't think so. Background means just that: background sky. E.g.: no nebulae, galaxies, ... Just stars and "empty" space. Background neutralization makes that sky neutral in color and may remove color biases in the picture.
Philip de Louraille
Offline Cosmick
« Reply #2 on: 2012 July 07 01:46:50 »
I think this is closer to how Colour Calibration is done. Background Neutralization is a bit like setting the blackpoint of each channel to the same point on the histogram. As Philip said -
« Last Edit: 2012 July 07 01:55:03 by Cosmick »
Clear Skies
Mick
« Reply #3 on: 2012 July 07 08:59:01 »
Hi Bob,
Not at all. The background neutralization algorithm is as follows:
INR = IR - BIR + b
ING = IG - BIG + b
INB = IB - BIB + b
where INR, ING and INB are the color channels of the resulting (background-neutralized image); IR, IG and IB are the original color channels; BIR, BIG and BIB are the mean backgrounds measured on the original channels, and b is the target mean background. Typically, b is defined by:
b = min( BRR, BRG, BRB )
where the BR's are the mean backgrounds measured on the background reference image.
Each mean background is estimated as the median of the pixels in the background sampling range (defined by the lower and upper limit parameters in the BackgroundNeutralization tool) for the corresponding channel of the original or background reference image.
