Hello,
I have the same problem with the ST-8300c, I tried everything in PI, the closest pattern is th GRBG in VNG. My work flow is: I take pictures with CCDOps and save them in .FITS format, calibrate pictures (in PI) with Bias, Dark and Flat, debayer. The result is closed but not like doing a debayer with CCDOps. The red that's going out is washed closest to the pink without depth. I use CLS CCD filter that I was also using with an ATIK 314L+ without any problems in PI. I suspect that the bayer matrix of ST-8300c is very different than the others.
Would be nice to get an answer about this fact.
