I just started playing with ProcessContainers derived from History and have a newbie question.
Is it possible to edit a process mask name in a ProcessContainer?
Sometime I break a link to a mask and then sometime later restore the mask and want to remove the <* broken *> flag.
Other times I am experimenting with different mask versions and just want to rename the mask to a different version and then replay the container.
Also, if the ProcessContainer contains a ImageIdentifier process instance, I'd like to change its name, again to reflect a different processing version.
Also, if the Container itself contains a ProcessContainer instance, I'd like to edit the names inside it.
Basically, anywhere a image window name occurs, I'd like to edit it.
Is this possible? Or is there some other way to accomplish something like this easily?
