Hi All,
I am starting to learn PI. My test dataset is images from the annular solar eclipse that I want to put into an animation. My starting point are about 120 images that I so far have converted from Canon RAW (CR2) into color channel separated TIFs.
I plan to use histogram, curves, unsharp mask, levels to further process. In the training video harry shows that some tools have a 'Global Apply' button. Unfortunately the histogram is not part of that. So what is the way to apply the same histogram operator to about 120 images? I tried open them all but the software crashed with memory problem. I can open subsets of the images and then apply manually, but that's a pain. What's the correct way to apply the same histogram operator to a larger set of frames? Even better would be to have a way to apply a prescribed sequence of operators to the set of images. Even better would be a way to save this entire processing pipeline to disk so that I can replay it at any time later.
I will ask questions on registration of the partial solar eclipse images later.
Your help is appreciated.
Thanks & Clear Skies,
Gert
