Author Topic: Out of memory  (Read 4474 times)
Offline TrickyDicky
Out of memory
« on: 2012 June 07 08:36:56 »
My laptop is WIN7-32-4GB and while trying to register image files (ARW or JPG) I have problems with "out of memory" error ....
Is this problem associated with 32-bit windows?
Re: Out of memory
« Reply #1 on: 2012 June 07 08:46:07 »
probably. this comes up from time to time and the answer is that W32 is depreciated and your out of memory problems will probably be resolved by using 64-bit windows/PI.
Offline topboxman
    • Peter's Gallery
Re: Out of memory
« Reply #2 on: 2012 June 07 10:16:09 »
I had 32 bit computer before upgrading to 64 bit. I had the same out of memory error as yours in 32 bit computer. In my case, it happens if I want to align or integrate over 30 subs. The way I resolve this is by changing the following for Image Integration:
Buffer size to 8MB
Cache to 4096MB
Peter
Offline TrickyDicky
Re: Out of memory
« Reply #3 on: 2012 June 11 02:36:15 »
Yes, it is 32-bit-system problem ....
It's a pitty it is not mentioned on the main PixInsight webpage, so people who intend to use it are warned/made aware about this issue.
Once switched to 64-bit OS the "out-of-memory" error goes away .....
Offline Andres.Pozo
Re: Out of memory
« Reply #4 on: 2012 June 11 02:48:54 »
The product FAQ recommends at least 6GB of memory and a 64bit O.S.:
http://pixinsight.com/sysreq/index.html#03
Offline TrickyDicky
Re: Out of memory
« Reply #5 on: 2012 June 11 05:28:36 »
I've seen that page, but there is a difference between recommending, and not workig, and the software has definitely problems with 32-bit OS ..... and "out-of-memory" issue .....
In other words, if you try to stack a few pictures with a 32-bit machine - you can't do it !!!!!!!!!
