Author Topic: Integration error message  (Read 2853 times)
Offline JGMoreau
« on: 2012 June 05 16:39:40 »
Hi, i have performed dozens of batch preprocessing runs, so far without problems.
On this last one however i get this error message.
As far as i can tell, image acquisition is my regular procedure, and i can't think
what might be different.
Any idea ?
Jean Guy Moreau
Offline Philip de Louraille
Re: Integration error message
« Reply #1 on: 2012 June 05 21:31:07 »
Shot in the dark: Abel24.00000001_c_cc_d_r.fit
The Empty format name, file extension...   error: maybe it is picking up .000.... as a file extension and not .fit?
Philip de Louraille
Offline cfranks
« Reply #2 on: 2012 June 06 05:45:02 »
Most of my images have similar sequence numbers so I don't think that is his problem.  I do notice at the top of his Process Console image, one of his images failed StarAlignment.  Could that be a genuine faulty image?
Charles
Offline JGMoreau
« Reply #3 on: 2012 June 06 10:09:15 »
You are right Charles, i removed the offending image from the stack
and everything proceeded as it should :)
JG Moreau
