Author Topic: How do you subtract your master bias info from your master dark?  (Read 3040 times)
Offline mcbbcn
What is the process for subtracting your master bias information from your master dark outside of the Image Calibration menu?  I'm asking because there is a pretty cool batch processing script to do all the calibration, registration & alignment in one go, but I don't believe it has a "calibrate checkbox" as you get in the image calibration, but I don't want to do an image calibration against lights in the image calibration menu, I just would like to have a Master Dark that has the Master Bias already subtracted.
Any thoughts?
Thank you,
Miquel
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
Hi Miquel,
I think you're looking for PixelMath. Try MasterDark - MasterBias (with the corresponding IDs)
Greetings,
Enzo.
astropixel
  • Guest
Load your bias and darks into the BP script and select calibrate only.
Offline mcbbcn
Thank you both!  Great tips!
