Author Topic: Dealing with preprocessingbatch with Orion Starshoot images  (Read 3440 times)
Offline afigueroa
I am using bias, darks and lights, no flats, it seems preprocessing batch go ahead to all the process i think in the final steps final image integration i receive a runtime error and the application is closed, i dont have any idea of what could be happend, someone with any ideas?
I have run the same images in DSS without issues. This is my first time using this batch process.
regards and thanks
Antonio F
« Last Edit: 2012 May 24 09:59:46 by afigueroa »
Offline afigueroa
Re: Dealing with preprocessingbatch with Orion Starshoot images
« Reply #1 on: 2012 June 25 17:27:59 »
This weekend a tried a new set of lights, darks, bias and flats, the error is the same, could be possible that camera is a color one?
regards
Antonio
« Reply #2 on: 2012 June 25 20:41:19 »
this is probably an out-of-memory issue. this is 32-bit Pixinsight, no?
you should probably not try to integrate from the batchpreprocsessing script, and instead load the calibrated lights into ImageIntegration. you need to reduce the buffer size and stack size and try again.
http://pixinsight.com/forum/index.php?topic=3545.msg25044#msg25044
