Author Topic: Problem: Batch Preprocessing of Canon DSLR images  (Read 3417 times)
Offline nmontec
    • SkyMonsters
« on: 2012 May 20 03:21:18 »
Dear All,
I wanted to calibrate some frames of mine acquired by a modified Canon EOS350D.
If I open a single raw frame and I use the autostretch feature I see it with "normal" colors, while if I calibrate and stack the light frames using the Batch Preprocessing, the image is completely yellow-shifted; looking at its histogram there is no sign of blue channel.
I already tried to change the debayering grid, with no success, I simply get a colour shifted stack.
I attach the two images for your reference, both with autostretch enabled.
Thanks a lot for your help.
astropixel
  • Guest
Re: Problem: Batch Preprocessing of Canon DSLR images
« Reply #1 on: 2012 May 20 05:49:31 »
Not sure. Can you post a screenshot of your BP script settings?
Offline Cleon_Wells
« Reply #2 on: 2012 May 20 09:40:02 »
When I use BPP on my T1i subs I always get more level in the R channel  then when I manually calibrate.
I've attached one 120sec-400iso sub from last night of M13, note the probe readout. I assume the difference is caused by the gray Masters files used during Calibration.
Cleon
PS I manually Calibrated with my normal Calibration files.
Rowland, I don't have a problem with ether Calibration methods.
« Last Edit: 2012 May 20 14:53:11 by Cleon_Wells »
astropixel
  • Guest
« Reply #3 on: 2012 May 20 12:15:41 »
Unless something is completely out of whack, ABE should fix this. I use a minimum of 3 iterations of ABE and find that colour is more evenly distributed, following colour calibration. Worth a try?
Offline Cleon_Wells
« Reply #4 on: 2012 May 20 13:27:20 »
I just added an Image in my last post showing the difference in the RGB levels between Manual Calibration and BatchPreprocessing Calibration , these images are from my T1i
