www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
General
Off-topic
StarAlignment Multiple images cannot be used as registration references
« previous
next »
Print
Pages: [
1
Author
Topic: StarAlignment Multiple images cannot be used as registration references (Read 5014 times)
ugatza
Newcomer
on:
2012 May 06 13:30:32 »
I try to align several images, but appears this message: "Multiple images cannot be used as registration references". Is the first time that happens this. Any solution?
Logged
sreilly
PixInsight Padawan
Re: StarAlignment Multiple images cannot be used as registration references
Reply #1 on:
2012 May 06 16:19:25 »
The top selection if for file/image as reference being a single image while the images to be aligned are in the larger box below. Are you sure you are only choosing one image/file?
I've never had an issue with this myself.
Logged
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
ugatza
Newcomer
Reply #2 on:
2012 May 06 16:29:58 »
Yes, only I choose one file/image (file, in this case). It´s strange this error message, in any case. Thank you for your reply, Steve.
Logged
Geoff
PixInsight Padawan
Reply #3 on:
2012 May 06 16:31:14 »
I had a similar problem with dark frames. Somehow PI had saved the dark and the two rejection frames under one file name. When I double clicked the filename, three files were revealed. Try double clicking your reference frame and see what happens.
Geoff
Logged
Don't panic! (Douglas Adams)
Astrobin page at
http://www.astrobin.com/users/Geoff/
Webpage (under construction)
http://geoffsastro.smugmug.com/
ugatza
Newcomer
Reply #4 on:
2012 May 07 03:55:11 »
I think that I´ve found the problem. The trouble was in the calibration process. Finally, I´ve took off the darks and now the staralignment works well. Thank you again for the replys.
Logged
Print
Pages: [
1
« previous
next »
PixInsight
General
Off-topic
