Author Topic: Command Line Interface  (Read 3245 times)
Offline cs_pixinsight
« on: 2012 May 03 20:15:00 »
I noticed the Command Line Interface prominently featured on http://pixinsight.com/features/index.html when I started trailing the software.  Now that I have purchased, I'd like to investigate this further and went looking for some documentation describing the list of commands that are possible.
I looked at the startup.scp file and it appears that a lot of standard Unix command are available.  I'm also looking for an reference material covering arguments you can pass into the modules/scripts.
Any help would be appreciated,
Craig
Re: Command Line Interface
« Reply #1 on: 2012 May 05 01:46:11 »
Hi Craig,
Enter the 'help' command to see a general description of the command line in PixInsight and a list of the commands currently available. To get extended help on a particular command, enter 'help <command>'. Unfortunately, we still have no official documentation for the CLI. Please feel free to ask anything related here.
The current command line interface is just a hint of what it is intended to be. It will be considerably extended in future versions of the PixInsight core application.
« Reply #2 on: 2012 May 05 09:20:02 »
Thanks for the help (pun intended) Juan, I'll check this out.  I initial tried man command for a manual page, but alas nothing came up.  Maybe an alias for man to help in startup.scp would solve that problem.  ;)  I've been used some form of Unix for the past 15 years now, so command line and shell scripting is second nature.  Glad to see that it will be a prominent feature in PI.
Craig
