Author Topic: BatchPreprocessing Empty format name  (Read 5183 times)
Offline Herbert_W
« on: 2012 May 03 00:53:43 »
I got this message during ImageIntegration:
What does it mean?
Your help would be very nice.
Now I have to go back to the startline
This is not a very comfortable deal with an error :-(
Best regards.
Herbert, Austria
Maybe the topic is wrong in this category, but I dont have an idea where to post it - sorry.
« Last Edit: 2012 May 03 01:04:17 by Herbert_W »
Re: BatchPreprocessing Empty format name
« Reply #1 on: 2012 June 07 00:53:35 »
Hi Herbert,
I apologize for the long delay in my answer. Just overlooked this report for some reason...
This problem has never been reported before. To help you I need a sample of the files you are integrating. On the screenshot you attached I can't see the whole file names of your images (they are cut at the right side of the console window), and this is crucial to understand what happens. Could you please copy here a relevant part of the text in PI's console after this problem happens?
Offline Cleon_Wells
« Reply #2 on: 2012 June 07 11:08:17 »
Juan, I've seen this same error, but not every time I run the BP script. When I get this error I manually select the _c_r subs and integrate.
Cleon
Offline Jack Harvey
« Reply #3 on: 2012 June 07 13:47:07 »
I have gotten it at least once, maybe twice?
Jack Harvey, PTeam Member
Offline Cleon_Wells
« Reply #4 on: 2012 June 07 16:45:45 »
Juan, here's where I  get a File format or File extension or MIME error.
Cleon
Offline cfranks
« Reply #5 on: 2012 June 08 17:52:22 »
Earlier in the Process Console, the StarAlignment failed on 6 images.  I think one of these may be causing your error.   http://pixinsight.com/forum/index.php?topic=4338.msg30447#msg30447
Charles
Offline Cleon_Wells
« Reply #6 on: 2012 June 09 11:57:53 »
Charles, for the heck of it after doing a BPP script on 19 T1i subs of M13 last night, which worked perfectly. I added one IZAR sub to the 19 M13 subs and got the ERROR. I assume the BPP script is looking for the number of Registered subs to equal the number of Debayered subs, maybe?
Cleon
« Last Edit: 2012 June 09 12:24:28 by Cleon_Wells »
Offline cfranks
« Reply #7 on: 2012 June 09 19:19:28 »
I've never used debayered images Cleon so I can't help there.  Did you determine why the StarAlignment didn't work on those 6 images?  Never having a need to look for it, I assume PI has a log file where the Process Console messages are kept.
Charles
Offline cfranks
« Reply #8 on: 2012 June 09 19:22:15 »
Sorry again Cleon, I just noticed you weren't the original poster thus having no access to the 6 images.
Charles
Offline Herbert_W
« Reply #9 on: 2012 June 10 00:10:41 »
Hi Juan,
this error is not repeatable and didnt happen with an other image.
I'm sorry to delete the data in the meantime - but the next time, ...
Thank you and best regards.
Herbert, Austria
Offline Cleon_Wells
« Reply #10 on: 2012 June 10 11:11:53 »
Herbert, i guess my instants of this Error is different, I can reproduce it every time when I get a failed sub during Registration.
I doubled checked this today with 6-lights and every time I changed one of the light subs out with a different object the Registration would give me one failed and then the Error occurred during Integration. My subs are from Canon T1i.
Cleon
« Last Edit: 2012 June 11 04:34:34 by Cleon_Wells »
Offline Herbert_W
« Reply #11 on: 2012 June 11 10:01:44 »
Hi Cleon!
Thanks for the hint with the failed sub during registration.
Maybe I had a failed sub as well - I will watch this next time.
Best regards.
Herbert
« Reply #12 on: 2012 June 11 11:20:48 »
Hopefully these problems will be gone in the new version 1.20, which I'll release in a while.
