Author Topic: noise estimates pre- and post- DBE  (Read 5570 times)
« on: 2012 April 30 17:43:10 »
does this make sense? even though subtraction is a linear operation, because the amount subtracted from each pixel is different, does it lead to this change in the noise?
integration1_clone
Calculating noise standard deviation...
* Channel #0
?R = 6.825e-05, N = 7072426 (57.14%), J = 4
* Channel #1
?G = 7.299e-05, N = 6927426 (55.97%), J = 4
* Channel #2
?B = 7.397e-05, N = 4916406 (39.72%), J = 4
integration1_clone_DBE
* Channel #0
?R = 2.917e-04, N = 7072600 (57.15%), J = 4
* Channel #1
?G = 3.120e-04, N = 6927503 (55.97%), J = 4
* Channel #2
?B = 3.162e-04, N = 4916273 (39.72%), J = 4
Offline mschuster
Re: noise estimates pre- and post- DBE
« Reply #1 on: 2012 April 30 18:48:25 »
I think this is relative noise, a measure of signal to noise. If so, then even if the amount subtracted is the SAME at every pixel signal to noise will change.
Example: Suppose image mean is 0.5 and absolute noise is +/- 0.05. Now subtract 0.4 from each pixel. Mean is now 0.1 but absolute noise remains the same at +/- 0.05. Signal to noise has decreased.
If you multiply an image by a constant, signal to noise does not change. But most any other operation changes signal to noise.
For more info see: M Newberry, Signal-to-noise Considerations for Sky-Subtracted CCD Data, ASP, Jan 1991.
« Reply #2 on: 2012 April 30 20:10:30 »
that makes sense. I was thinking in terms of a histogram and why subtracting a value would cause the shape of the histogram to change. but yeah, if you move the signal down by subtracting it stands to reason that the noise becomes a larger percentage of the signal.
Offline mschuster
« Reply #3 on: 2012 April 30 21:05:22 »
As a test, I tried subtracting a constant. NoiseEvaluation gave the same noise value. So what I said does not apply; this noise is not SNR related. I also tried DBE on an integration, noise change was negligible or small (3.03e-4 to 3.06e-4 for division and 3.03e-4 to 3.15e-4 for subtraction). I don't know what is going on in your case.
« Reply #4 on: 2012 April 30 21:49:13 »
yeah i was going to try subtracting a constant from my data before posting but i got lazy.
here is the file if anyone cares to look at it. the screenshots show the statistics of the original image, background image and corrected image.
http://endor.uv.es//data/public/fb41b86a1c2322c6426b723dfb26de9b.php?lang=en
Offline mschuster
« Reply #5 on: 2012 April 30 22:09:42 »
I'm getting a cannot find file error on your link.
« Reply #6 on: 2012 April 30 22:33:39 »
do you have an account on the endor pixinsight filesharing machine?
it's in the Forum shared files area under "pfile"
if not i can post it somewhere else...
Offline vicent_peris
    • http://www.astrofoto.es/
« Reply #7 on: 2012 May 01 00:55:39 »
Are you subtracting or dividing by the background level?
V.
« Reply #8 on: 2012 May 01 08:53:07 »
hi vicent... always subtracting. i usually only divide when i am looking at a single sub with no flat and i want to approximate a flat just to see the field better.
