Author Topic: PJSR: Changing the ID of an image  (Read 4369 times)
Offline bitli
« on: 2012 April 15 05:59:07 »
From a script,  I try to change the ID of an image generated by a previous process.  Apparently this calles the ImageIdentifier process, it changes the ID correctly but generates an error message about an invalid image (see image).
Any clue?
-- bitli
Offline bitli
Re: PJSR: Changing the ID of an image
« Reply #1 on: 2012 April 22 08:10:54 »
The mistery is solved. In case this may be useful to somebody else:
I was running ABE from a script, asking ABE to generate new image but NOT the background. The I was renaming all generated main views after tunning ABE.
But in fact ABE still generate the background, it is just invisible, but returned in the list of all views. Changing the id of that invisible window was causing the error (it seems that the view is still locked by the process, may be this is the root cause).
Anyhow I do not need that view, as I explicitely asked not to get it, so now I detect invisible windows and skip them.
-- bitli
