Author Topic: When is the best time to use Local Histogram Equalization (LHE)?  (Read 4916 times)
Offline topboxman
    • Peter's Gallery
I recently discovered how valuable Local Histogram Equalization (LHE) is. Lately I use this at the very end of processing with PixInsight. This is my typical process procedure with my SXVR-M25C OSC CCD camera:
1) Calibration and DeBayer each sub
2) Star Alignment and Image Integration
3) Dynamic Crop
4) DBE
5) Background Neutralization and Color Calibration
6) Multiscale Median Transform with Noise Reduction
7) Histogram Stretch
8 ) SCNR to remove green gradients
9) Create Star Mask
10) HDR Multiscale Transform with Star mask to protect the stars
11) Curves Transformation using Saturation with Luminance mask
12) Curves Transformation using RGB/K
13) LHE
I've stopped using ACDNR thanks to Multiscale Median Transform with Noise Reduction. MMT does a great job removing background noise while the image is still linear.
Is there a better time to do LHE besides at the very end of processing?
Peter
Hi Peter,
I think there is not an specific place. Use it after HT. I found very usefull to do it before saturation. Depending on the intensity applied you will see lost of color that can be recovere with saturation.
Regards, Alejandro.
Offline vicent_peris
    • http://www.astrofoto.es/
After HDRMT.
Vicent.
Offline topboxman
    • Peter's Gallery
Thanks.
Peter
