Author Topic: Preview of image processing tutorial results: NGC 5189 from Gemini Observatory South  (Read 5759 times)
(Texto en Español abajo)
Happy Halloween to everybody.
Today I'd like to show you the resulting images from the incoming tutorial on high dynamic range wavelets and deconvolution in PixInsight, which I'm writing right now.
This first tutorial is about a famous image of NGC 5189 from the Gemini Observatory South. See for instance:
http://www.gemini.edu/index.php?option=content&task=view&id=188
And here are my results with the same Ha, OIII and SII raw data:
1. The image after RGB combination and the initial nonlinear stretch with HistogramTransform:
http://pteam.pixinsight.com/Gemini/NGC5189/test-01/00.jpg
2. After HDRWaveletTransform:
http://pteam.pixinsight.com/Gemini/NGC5189/test-01/02-no-decon.jpg
3. The final image:
http://pteam.pixinsight.com/Gemini/NGC5189/test-01/02.jpg
This is the result of:
- Inverse HistogramTransform to go back to a linear image.
- Regularized Richardson-Lucy deconvolution with active deringing.
- Back to nonlinear space with HistogramTransform.
- Masked ACDNR noise reduction, applied to the background only.
I have applied just 20 iterations of RRL. The SNR of the original data is extremely high --the highest SNR I've ever seen in a deep-sky image! I seem to be able to apply an "unlimited" number of deconvolution iterations, keeping the noise tightly controlled with regularization. But 20 iterations just show everything without overprocessing the image, so, why more?
There are a few cosmetic problems in the above image, like the blooming of the bright star and a few bad pixel rows. Maybe I'll spend some time to fix them, depending on how long it takes to write this tutorial.
Thanks to Vicent Peris for downloading and preparing the raw data for me, which has saved me a lot of time.
Comments welcome!
Felices vacaciones a todos (los que las tengáis ;) )
Hoy quisiera mostraros las imágenes resultantes de un nuevo tutorial sobre procesamiento de imágenes de alto rango dinámico con wavelets y deconvolución en PixInsight, que estoy escribiendo ahora mismo.
Este primer tutorial sobre el tema usa una famosa imagen de NGC 5189 del Gemini Observatory South. Mirad por ejemplo:
Y aquí están mis resultados con los mismos datos originales en bandas Ha, OIII y SII:
1. La imagen después de la combinación RGB y un ajuste no lineal inicial con HistogramTransform:
2.  Tras aplicar HDRWaveletTransform:
3. La imagen final:
Éste es el resultado de:
- Ajuste inverso con HistogramTransform para volver a una imagen lineal.
- Deconvolución con Richardson-Lucy regularizado, con deringing activo.
- Vuelta a la distribución no lineal con HistogramTransform.
- Reducción de ruido ACDNR con máscara de luminancia, sólo para el fondo.
He aplicado sólo 20 iteraciones de RRL. La relación señal/ruido (RSR) de los datos originales es increíblemente alta --la RSR más alta que he visto nunca en una imagen de cielo profundo! Parece que podría aplicar un número ilimitado de iteraciones de deconvolución, manteniendo el ruido perfectamente controlado gracias a la regularización. Sin embargo, 20 iteraciones bastan para mostrar todo lo que hay, sin sobreprocesar la imagen. Así que, ¿para qué mas?
Quedan unos cuantos problemas de tipo cosmético en la imagen de arriba, como el blooming de la estrella más brillante, y unas cuantas filas de píxeles muertas. Puede que invierta algo de tiempo para resolver estas cosas, siempre que escribir el tutorial no me lleve más tiempo de lo esperado.
Gracias a Vicent Peris por preparar los datos originales para mí, lo cual me ha ahorrado una gran cantidad de tiempo.
Cualquier comentario será bienvenido.
Offline Jordi Gallego
Hola a tod@s,
el resultado es impresionante Juan, por la mejora en la visualización del detalle escondido en la imagen :shock: ,por favor acaba el tutorial pronto :D  :D  :D !!!
Una cosa que no entiendo es que el punto 2 dices "tras aplicar HDRwavelet" pero luego comentas que lo que has aplicado es Richardson Lucy?
Saludos
Jordi
Jordi Gallego
www.astrophoto.es
Offline vicent_peris
    • http://www.astrofoto.es/
Quote from: "Jordi Gallego"
Saludos
Jordi
Hola Jordi,
lo que quiere decir Juan es que la imagen 3 es el resultado de aplicar:
a la imagen 2.
Los HDRWavelets van muy bien, sobretodo cuando el rango dinámico es muy grande, para preparar la imagen para la deconvolución. Por lo tanto, lo que se hace es hacer un ajuste de medios tonos, luego los HDRW, y luego otro ajuste de medios tonos de 1 menos el valor de medios tonos aplicado anteriormente, para devolver la imagen a su estado "lineal". Piensa que la deconvolución tiene su justificación física cuando la imagen está en lineal, puesto que entonces la PSF es invariante respecto de la iluminación local de la imagen.
Saludos,
Vicent.
Offline Maxi
  • Barcelona / España - Spain
    • http://www.astromodelismo.es/index.htm
Pues digo lo mismo que Jordi , tutorial ya,  :P
He abierto las dos imagenes a la vez para poderlas comparar y es una pasada lo que has conseguido  :shock:
Saludos
Offline GABRI 9555
    • http://www.pbase.com/gabriel_medina_9555/universe_in_narrowband
hola, es asombroso la cantidad de detalles que habeis extraido de la imagen , reitero , tutorial  :lol: .
saludos / regard
Gracias por la aclaración Vicent :wink: !!
Saludos
Jordi
Jordi Gallego
www.astrophoto.es
