Author Topic: Tools for Linear vs Non-linear images  (Read 17750 times)
Offline cs_pixinsight
« on: 2012 March 29 09:30:39 »
Is there any reference documentation which explains which PI tools work best on linear images, which work best on non-linear and which can be used equally well on both?
Craig
Offline Lex
  • We do it at night...
Re: Tools for Linear vs Non-linear images
« Reply #1 on: 2012 March 29 12:48:38 »
Craig,
That's a nice question, this would interest me also because i still struggle with the if or not  O0
Hope the pro's here have an answer...
Clear Skies!!
Lex
Offline Warhen
    • Billions and Billions
« Reply #2 on: 2012 March 29 21:01:54 »
Hey guys! I'm newer at this than many here, but... here goes:
My linear tools: STF, Fast Rotation, Dynamic Crop, RGB Working Space assignment, ABE, DBE, Color Calibration, Dynamic PSF and Deconvolution, ATrous Noise reduction
Nonlinear: Auto Histogram and Histogram Transformation, ACDNR NR, HDR Median Transform, Local Histogram Equalization, Morphological Transform, Saturation Curves, SCNR-G if needed
Hope that gets the ball rolling!
Best always, Warren
Warren A. Keller
www.ip4ap.com
Offline Lex
« Reply #3 on: 2012 April 01 14:49:50 »
Warhen,
Thanks for that, i thought there were more differences  ???
Clear Skies!!
Lex
« Reply #4 on: 2012 April 02 11:49:00 »
Warren, thank you for taking the time to detail the tools you use.  I wanted to wait in replying to give others a chance to review.  I was hoping they would give their opinions concerning how you felt the tools should be used and add to the list to get most of the tools/scripts covered.
One question on deconvolution.  Should the support mask be linear or non-linear?  I also assumed that a star mask was used, which means to me that the image should be black for the stars and white elsewhere.  Is that assumption correct?
Here are the tools which are still not covered.  I'm sure a complete list would be helpful to all PI users, especially newbies like myself.  Hopefully others will be able to help complete this list and the authors of the scripts will be available to help itemize where they work best.
Processes:
  • AssistedColorCalibration
  • BackgroundNeutralization
  • ChannelCombination
  • ChannelExtraction
  • ChannelMatch
  • CloneStamp
  • ColorSaturation
  • Convolution
  • DefectMap
  • DigitalDevelopment
  • DynamicAlignment
  • FourierTransform
  • GradientHDRComposition
  • GradientHDRCompression
  • GradientMergeMosaic
  • GREYCstoration
  • HDRComposition
  • HDRMultiscalTransform
  • ICCProfileTransformation
  • InverseFourierTransform
  • LarsonSekanina
  • MultiscaleMedianTransformation
  • NoiseGenerator
  • RangeSelection
  • RestorationFilter
  • SimplexNoise
  • StarAligment
  • StarMask - I'm very curious about this one
  • UnsharpMask
Scripts:
Image Analysis:
  • ExtractWaveletLayers
  • ImageSolver
  • NoiseEvaluation
Instrumentation:
  • CalculateSkyLimitedExposure
Utilities:
  • BackgroundEnhance
  • CanonBandingReduction
  • CosmeticCorrection
  • DarkStructureEnhance
  • DeconvolutionPreview
  • FFTRegistration
  • StarHaloReducer
« Last Edit: 2012 April 02 11:54:19 by cs_pixinsight »
Offline Warhen
« Reply #5 on: 2012 April 03 09:18:49 »
Hi guys! Yes I'd certainly hope more experienced users will weigh in too. Still, to answer your questions as I understand them- correct, the deringing 'local support' star mask should protect the larger stars. Regarding the general mask to protect areas we don't wish to deconvolve, it's just much easier to define a good mask when the source image is nonlinear. To that end, leave the image in the linear space but use a clone to apply a nonlinear histogram transform to, then use Range Selection on the clone to create your mask and apply it to the original, linear image. CS_PI, of the items in your list and ones I did not mention- I regularly use: Star Mask and Range Selection for masks, and the DSE and BE Scripts.
Best always, Warren
Warren A. Keller
www.ip4ap.com
« Reply #6 on: 2012 April 06 13:51:06 »
I'll keep updating this list as I come across discussions indicating which type of image they should used upon.  Feel free to update anything you know about too or correcting what I have outlined!
Tools working on linear and non-linear images equally well:
   AutoHistogram
   CurvesTransform
   DynamicAlignment
   HistogramTransformation
   IntegerResample
   Invert
   RangeSelection
   RGBWorkingSpace assignment
   Rotation
   StarAlignment
   Statistics
   processes that only alter the physical shape of the image
Tools best used on linear images:
   ATrousWavelet Noise reduction
   AutomaticBackgroundExtraction
   Color Calibration
   Fast Rotation
   Deconvolution
   DynamicBackgroundExtraction
   Dynamic Crop
   Dynamic PSF
   GradientMergeMosaic
   GREYCstoration
   HDRComposition
   ImageCalibration
   ImageIntegration
   ScreenTransferFunction
Tools best used on non-linear:
   ACDNR NR
   CurvesTransformation - for saturation
   HDRMultiscaleTransform
   LocalHistogramEqualization
   MorphologicalTransform
   SCNR
That leaves the following uncategorized:
Processes:
   ChannelCombination
   ChannelExtraction
   ChannelMatch
   CloneStamp
   ColorSaturation
   Convolution
   DefectMap
   DigitalDevelopment
   FourierTransform
   LarsonSekanina
   NoiseGenerator
   RestorationFilter
   SimplexNoise
   UnsharpMask
Scripts:
Image Analysis:
   ImageSolver
   NoiseEvaluation
Instrumentation:
   BasicCCDParameters
Utilities:
   BackgroundEnhance
   CosmeticCorrection
   FFTRegistration
   StarHaloReducer
Craig
« Reply #7 on: 2012 April 06 14:12:20 »
Here some tools where I would suggest a different classification
   Fast Rotation: Linear and non-linear
   Dynamic Crop: Linear and non-linear
   GradientMergeMosaic: Linear and non-linear
   ScreenTransferFunction: Linear and non-linear
   MorphologicalTransform: Linear and non-linear
   CloneStamp: Linear and non-linear
   DefectMap: Linear
  NoiseGenerator: Generates new image
   ImageSolver: Linear and non-linear
   NoiseEvaluation: LInear
   BasicCCDParameters: Linear
   CalculateSkyLimitedExposure: Generates number only
   CanonBandingReduction: Linear
   CosmeticCorrection: Linear
« Reply #8 on: 2012 April 06 15:24:56 »
Thanks Georg, your input has been incorporated and I classified a few more.
   AutoHistogram
   CalculateSkyLimitedExposure - just generates numbers based on input
   CloneStamp
   CurvesTransform
   DynamicAlignment
   DynamicCrop
   Fast Rotation
   GradientMergeMosaic
   ImageSolver
   IntegerResample
   Invert
   NoiseGenerator - generates a new image
   RangeSelection
   Rotation
   StarAlignment
   Statistics
   BasicCCDParameters
   ColorCalibration
   CosmeticCorrection
   Debayer
   Deconvolution
   DefectMap
   DigitalDevelopment
   Dynamic PSF
   ExponentialTransform
   HDRComposition
   ImageCalibration
   ImageIntegration
   LinearFit
   NoiseEvaluation
   ACDNR NR
   GREYCstoration
   SCNR
   StarMask - seems to work better on a clone which is non-linear (i.e. stretched), but will work on both types.
Processes:
   ChannelCombination
   ChannelExtraction
   ChannelMatch
   ColorSaturation
   Convolution
   FourierTransform
   LarsonSekanina
   RestorationFilter
   SimplexNoise
   UnsharpMask
Scripts:
Utilities:
   BackgroundEnhance
   FFTRegistration
   StarHaloReducer
Craig
Offline Lex
« Reply #9 on: 2012 April 07 04:19:33 »
That's nice, a good and correct list with all the great utilities in the right order  O0
Clear Skies!!
Lex
Offline sreilly
« Reply #10 on: 2014 April 26 09:44:56 »
While this is a great list and most helpful it is by now  over two years old. To keep the information up to date, any additional tools/processes to add? Or has this been done elsewhere I haven't seen?
-Steve
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
