Author Topic: Grainy Images with new Setup?  (Read 6557 times)
Offline Lex
  • We do it at night...
« on: 2012 March 22 14:45:21 »
Hi Forum,
I offered my self a new 10" Carbon-tube Newtonian at f5.
I tried to shoot a couple of images with M51 as model, unfortunately i had to see a really grainy image while processing.
Is it good to crop the image before beginning to process or not?
Is there a rule what binning mode to be used with different focal lengths?
I have the Atik383l+ and i never encountered this type of Grainy images with my Triplet-Apo, binned once ore twice; no difference..
Could it be a focussing issue; i don't think so because I used Focus Max to image @ a FWHM of 1.6...
Guys help me out, what can it be or is there a way to easily soften this problem in PI? I tried ACDNR but not a big change for this images..
I have acquired about 3 hours of Data and it would be a shame to dump it  ???
So let me know what you know  >:D
Thanks!!!
Clear Skies!!
Lex
Offline ManuelJ
    • ManuelJ Photography
Re: Grainy Images with new Setup?
« Reply #1 on: 2012 March 23 00:28:17 »
Please post an example
Offline Lex
« Reply #2 on: 2012 March 23 08:23:20 »
Hi Manuel,
Exactly that's what I wanted to do  ^-^
So here we are:
Clear Skies!!
Lex
Offline Lex
« Reply #3 on: 2012 March 23 08:36:10 »
I think that I have compressed this one to much, hereafter is another one..
So the image details are:
L: 10x300s Bin 1x1
RGB: 5x300s Bin 2x2
Total: 75 minutes
Equipment used: 10" f5 Newtonian, Atik 383l+, CGEM, Lodestar.
Soft: Combined in MDL and processed in PI with the usual steps ( Background Neut.; Color Calib; SCNR - Green; HDRWT; DBE; Histogram; Curves...)
I know the exposure time is kind of short, but even at 1 hour I never encountered this grainy artefact..
Is it perhaps I bin twice my RGB? Is there something wrong with the cam?
Should I try longer exposures or more short ones?
I really do not know...
Clear Skies!!
Lex
Offline ManuelJ
« Reply #4 on: 2012 March 26 03:47:00 »
I don't see anything wrong with that image. Are you talking about the large scale noise in the background?.
All my images have that kind of noise :) . I think it's something related to the image scale.
Solution: expose more time, do not overstretch.
Offline Lex
« Reply #5 on: 2012 March 26 04:49:40 »
Manuel,
Thank you for the answer! Now that I know, that even you have that kind of noise in your images; knowing your stunning results; everything is fine for me  8)
I did some more exposures, and effectively saw that the noise had gone a bit...
It is a challenge for me to master my new equipment and the related differences in the images..
Another question: Do you completely calibrate all of your images through the different filters with adapted calibration frames (Flats, Darks, Bias's)
I think this is one of the origins of the noise in my M51, I try to get good Flats but it is really not working...
Clear Skies!!
Lex
Offline ManuelJ
« Reply #6 on: 2012 March 27 00:18:01 »
Yes, of course. I take flats for every filter and calibrate them with a scaled dark.
It's important to have calibration data no more than 2-4 weeks old.
How are you obtaining your flats?
Offline Lex
« Reply #7 on: 2012 March 27 12:18:01 »
Manuel,
I am trying to obtain my flats of e Gerd Neumann ELP, i think that this source is kind to bright, I will try to dimm with some sheets of paper...
So for the flats, have they got to be of the same lenght of the image exposure? Or does it reach out if you take 20x2sec and then combine them and average them? Have got to treat them with bias or darks?
What about the last ones?
Sorry for the questions but the wonderful images, inclusive especially your make me go crazy, and i simply try to get further  :o
Thanks a lot!
Clear Skies!!
Lex
Offline ManuelJ
« Reply #8 on: 2012 April 02 00:25:14 »
Manuel,
Thanks a lot!
If your camera does not have a shutter, taking short flats (1-5 sec) is not a problem.
Flat don't need to be of the same exposure. Just expose until the median of all pixels in the image is arount 20000-25000 ADU, take at least 20 of them for each filter.
Follow this great tutorial for calibration: http://pixinsight.com/tutorials/master-frames/en.html
Trying to improve yourself is the way to go, good luck!
Offline Lex
« Reply #9 on: 2012 April 07 04:28:01 »
Manuel,
Thank you very much for your help! I am using PI for over a year now, sometimes I obtain really nice results but I think this is more a coincidence  ???
What i do now is to really go deeper into the soft and try to inderstand what the different terms do mean, but this obviousely is not the easiest thing..
In the begining you can pratically leave the default settings and sliders unchanged but wanting better results it is not like that anymore  :o
It is difficult to figure out the different technics because I don't have a "real" usermanual to check out.
Anyway thanks very much and respect again for your incredible pictures!
Clear Skies!!
Lex
