Hi Ray,
I have the preview box checked, and then when I goto apply the image to a preview, it just seems to change into a negative image. But I'm still not getting numerous images like in the tutorial.
That inverted (negative) image is precisely a wavelet layer. Well, speaking more accurately, it is a
visible representation of a wavelet layer, that you can use to inspect the image structures it contains.
There is no way to automatically split an image or preview into a series of wavelet layers in a single operation. You have to obtain one at a time and then use the Preview > Make Image menu option to extract it into a new window.
The next versions of PixInsight will include this automatic extraction feature and much more extended capabilities for wavelets processing. Basically, you'll be able to work with wavelet layers as independent images.
Also, what is the slider bar for that is under the "Preview" check box?
It is a simple gamma adjustment. Sometimes a wavelet layer is hard to inspect because its contrast is very poor. By increasing the gamma slider control you can make it more easily visible.
Does the 'currently selected layer' mean the preview i've created and have currently selected? Or does it mean a 'wavelet plane'?
I meant the wavelet plane (you can call them planes or layers, both words are valid) that is currently selected on the À Trous Wavelets window.
When I goto "make image" I just get an exact copy of the negative preview image. Should I be doing something else here?
No, that exact copy is just the wavelet plane you are looking for. The only thing you might want to do is inverting it to get a positive image (press Ctrl-I, or use Image > Invert). This is what we usually do when we put examples on tutorials and processing examples.
When you say "preview objects" I take that to mean the previews I've created and not wavelet planes. Is this right?
Correct. Preview objects are the volatile subimages that you create within a window by using the New Preview mode.
Thanks again for your help. I'm very new to digital processing, but I am enjoying the learning curve associated with it.
Thank
you for your interest. You'll enjoy it much more as you gain experience and knowledge.
Juan
