Author Topic: HDRMT question  (Read 3999 times)
Offline JGMoreau
HDRMT question
« on: 2012 March 13 08:00:17 »
Hi everyone,
I am having difficulty with the HDRMTransform process.
It appears to give different results when applied to cropped image vs full image, see :
http://www3.cablevision.qc.ca/astro/Clipboard01.jpg
Same with previews.
I must be missing something.
Windows 7, 64bits, 8 Gig ram
Thanks for helping,
Jean Guy Moreau
Quebec
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
Re: HDRMT question
« Reply #1 on: 2012 March 13 08:10:52 »
This is normal behavior. Try to make a preview from whole picture.
Greetings,
Enzo.
ruediger
  • Guest
Re: HDRMT question
« Reply #2 on: 2012 March 13 08:29:25 »
I think, because the median values of the overall picture and the preview are very different.
Often it is very odd, that a well-tested sequence of processes, carried out on a small crop of the picture to speed up processing time, can't be transferred to the whole picture because of very different results of HDRMT or others.
Rüdiger
Offline JGMoreau
Re: HDRMT question
« Reply #3 on: 2012 March 13 09:44:44 »
Hi Enzo, normal behavior ?   :-X
I tried whole picture preview, no joy.
It seems related to the size of the image...
Rüdiger, thanks for the median value explanation.
Does this suggest a workaround, or a way to make good use of the process ?
Suggestions ?
JG Moreau
ruediger
  • Guest
Re: HDRMT question
« Reply #4 on: 2012 March 13 11:18:54 »
A workaround in this particular case might be to test all parameters on a scaled down duplicate of your image.
I don't know how many processes can lead to different results dependent if executed on a preview or the full image. Perhaps it's possible to add additional options like "(x) take median value from ..." etc. to ensure you safely can transfer a process setting from a preview or a crop to the whole image and getting the same result.
Rüdiger
Offline JGMoreau
Re: HDRMT question
« Reply #5 on: 2012 March 14 09:51:41 »
Answering my own question here  :)
Simply deselect the Automatic Midtone Balance button, and adjust to taste, 0.15
for this image.
Ah! those automatic things ;)
Bye,
JG Moreau
