Author Topic: Image Solver Script disappeared  (Read 3741 times)
Offline luigis
« on: 2012 March 13 07:21:48 »
I was playing yesterday with the ImageSolver script. I found it under scripts/image_analysis after the last update.
But today I launched PI and the script is gone from the menu. I checked updates and it said it was up to date and the updates log said the script was installed.
What happened to the script?
Thanks for the help!
Offline Philip de Louraille
Re: Image Solver Script disappeared
« Reply #1 on: 2012 March 13 10:34:16 »
I just checked. Before the update, that script did not exist. I updated. Restarted PI and the script is there. I quit PI and restarted and the script is still there.
So... maybe you did not start the same version of PI? For instance, updating the 64-bit version won't update the 32-bit version. Just guessing...
Philip de Louraille
Offline luigis
« Reply #2 on: 2012 March 13 11:02:20 »
It was different for me:
The script wasn't there
I updated
The script appeared
I close PI, restarted
and now the script is gone.
But the update log says it was installed yesterday.
Any way to make it show up again?
« Reply #3 on: 2012 March 13 11:10:15 »
Under the script menu, select the Feature Scripts...
A windows open and see if, under Image Analysis, ImageSolver is present (in my case, between extractWaveletLayers and NoiseEvaluation)
If it is present, select it and click Add (or Regenerate?) found at the bottom of the window.
Or Select all and Regenerate?
Guessing again now..
Philip de Louraille
Offline Andres.Pozo
« Reply #4 on: 2012 March 13 11:12:05 »
You can try this:
  • Enter in "Script \ Feature scripts..."
  • Execute "Regenerate"
The script should appear in the list.
If that fails you can check that there is a imagesolver.js file in %PROGRAMFILES%\PixInsight\src\scripts. If there isn't, you can download the script from http://pixinsight.com/forum/index.php?topic=3911.msg27378#msg27378, then save it in any directory, and finally add this directory using the button "Add" in "Script \ Feature scripts..."
You should also read this message by Juan and my reply:
http://pixinsight.com/forum/index.php?topic=3911.msg27406#msg27406
Offline luigis
« Reply #5 on: 2012 March 13 11:39:00 »
You can try this:
Thank you VERY much, got it back to the menu now :)
