Author Topic: PCL: Comet Alignment module  (Read 66313 times)
Offline NKV
Re: PCL: Comet Alignment module
« Reply #45 on: 2012 December 25 02:12:29 »
v1.0.3 for PI 1.8 RC1 Linux64
« Reply #46 on: 2013 January 05 16:20:23 »
v1.0.3 for PI 1.7 MacOSX x86_64
http://endor.uv.es//data/public/adc4c121f0951f1a5b78286e97e9473e.php
i'll build for 1.8 when i get my new PCL environment established
Offline NKV
« Reply #47 on: 2013 February 05 00:38:18 »
Bin for PI 1.8 RC3:
Linux x64
Win x32
Win x64
« Reply #48 on: 2013 March 06 07:15:06 »
Hi :)
I'm trying to download the linux 64bits version, for 1.7, but the link doesn't work (well, not a single link to endor here works...). It is my problem, or do you experience the same?
Offline FunTomas
    • Astrofoto.sk
« Reply #49 on: 2013 March 06 12:10:06 »
Hi Carlos. This is general problem of the links. I got the same error.
Offline NKV
« Reply #50 on: 2013 March 06 20:47:45 »
Something wrong in repository.
All links updated.
Offline Herbert_W
« Reply #51 on: 2013 March 06 22:43:49 »
Hi!
the links are ok now, but for win 32bit and win64bit comes the CosmeticCorrection tool.
Click on the image to download
CosmeticCorrection-pxm_PI1.8RC3_Win64_1.0.3.0001.rar
to your hard drive
Best regards.
Herbert, Austria
Offline f11
« Reply #52 on: 2013 March 15 21:28:37 »
Hi Herbert - if you haven't already done so, just download the module. When you unzip it, it is indeed the CometAlignment-pxm.dll you're looking for.
Unzip the file, then move or copy it to the C:/Program Files/PixInsight/bin/ subdirectory, then start PI.
Open the Process menu, and at the bottom you'll see "Modules".  Choose "Install Modules...".  A dialog box pops up with no new modules in it.  Press "Search" in bottom left corner of dialog, and the new module will be identified as "new" and added to the selection list.  Select it from the list, and hit "Install".  The Process Console will do its thing and show the following when done:
Module Id ............ CometAlignment
Version .............. 01.00.03.0001
Language ............. eng: English
Development status ... <* Unspecified *> (release)
Release date ......... 2012/12/25
Author ............... Nikolay Volkov
Copyright ............ Copyright (c) 2012 Nikolay Volkov
Trade marks .......... PixInsight
Original file name ... CometAlignment-pxm.dll
API version .......... 138
Module Description:
CometAlignment module
You're done!
Rod
Offline NKV
« Reply #53 on: 2013 March 27 22:52:27 »
Bin updated for PI 1.8 RC5:
Linux x64
Win x32
Win x64
Best regards,
Nikolay.
Offline Giorgio
« Reply #54 on: 2013 March 28 01:19:30 »
Hello Nik
I can not find the file CometAlignment-pxm.dll,
in zip files i find it kind CPP and H, not pxm.dll
thanks.
Giorgio
Offline NKV
« Reply #55 on: 2013 March 28 01:24:20 »
Giorgio, you downloaded C++ Sources code package.
Try to download Bin for PI.
Best regards,
Nikolay.
Offline Giorgio
« Reply #56 on: 2013 March 28 04:43:49 »
Thank you Nikolay
everything works
Giorgio.   :)
Offline NKV
« Reply #57 on: 2013 April 22 04:10:35 »
Some program generate FITS file with different DATE-OBS format. See doc
So, the module crash if DATE-OBS deffer from format 'yyyy-mm-ddThh:mm:ss.sss'
v1.0.4.1 BugFix. added support for short format (DATE-OBS + TIME-OBS)
Offline RafaRo
« Reply #58 on: 2013 May 05 23:53:40 »
Hi, i can't load images in Coment aligment tool..., it's don't load, nothing . I use 1.8 RC7
Plase i need help.
Rafael
Offline NKV
« Reply #59 on: 2013 May 06 00:28:17 »
Plase i need help.
Impossible without your files...
Give me link where is i can download your files.
And which OS you use?
