Author Topic: New to PI with a question about Wavelets  (Read 3560 times)
Offline luigis
« on: 2012 March 10 04:57:12 »
Hi All,
I'm happy to joint the PI community.
I'm learning how to use PI for Multiscale processing.
I'm having a simple problem that is driving me crazy.
Let's say I have an image "I".
I use wavelets to extract the 128 pixel level I call this I_L (Large)
I calculate I_S = I - I_L
And I have also the small details.
If I do I_S + I_L I get the original image "I", eveything is fine.
But now I want to decompose I_L into two images too
so I use wavelets to extract the 128 pixel level from I_L and I call this I_VL (very large)
I calculate I_LS = I_L - I_VL
but now if I do I_LS + I_VL the result is not I_L, it is different.
So I decompose one image into two levels but I can decompose one of the levels into sub-levels.
So my questions are:
1) Why is this happening and what am I doing wrong?
2) How can I do what I want to do? (Decompose an image in 3 levels that added will result in the original image)
Thanks a lot for your help!
Luis
Re: New to PI with a question about Wavelets
« Reply #1 on: 2012 March 11 14:26:15 »
Hi Luis, welcome to the forum.
What you are doing is ok. Do not rescalete when you add l_LS + I_VL and the result will be I_L
Saludos.
Alejandro.
Offline luigis
« Reply #2 on: 2012 March 11 14:44:33 »
Saludos.
Alejandro.
Hi Alejandro,
I've tried without rescale when I add I_LS + I_VL but the result is still different. I'm getting crazy!  O0
Any ideas?
Gracias!
« Reply #3 on: 2012 March 11 15:25:31 »
Hi Luis,
I made a quick example. See the parameters in PixelMath
Original Image
Clone and apply ATWT to clone
Subtract from image
Clone the clone and apply ATWT to clone_clone
Substract clone_clone from clone
Now adding clone + clone_clone without rescalete
And add Image + clone but enable rescalate
Original image recovered
Hope this helps.
Saludos.
Alejandro.
Offline luigis
« Reply #4 on: 2012 March 11 17:45:56 »
Hi Alejandro,
Thanks! But I'm getting dizzy.
Why do you do l+l_clone twice at the end ?
I have an Image
I apply wavelets to obtain large structures
I substract the large structures from the original to obtain small structures
So I have Image = Small + Large (this works!)
Now why I can't do the same to "Large" ?
I apply wavelets to "Large" to obtain "Large_Large"
and I do Large_Small = Large - Large_Large
but now Large_Small + Large_Large <> Large  Why is this happening? why it doesn't work like with the original image? What is different?
« Last Edit: 2012 March 11 17:53:17 by luigis »
Offline luigis
« Reply #5 on: 2012 March 11 19:37:33 »
Now I think I got it working. Thanks a lot for your help Alejandro!
