Author Topic: Image Plate Solve Script  (Read 58331 times)
Offline cbradshaw
    • Charlie's Tree House Observatory
Re: Image Plate Solve Script
« Reply #60 on: 2012 August 13 03:43:59 »
I can save to an icon and I can drag the entire header to another image, but I cannot drag a single keyword from one image to another.  Perhaps I misunderstood the context.
Charlie
Charlie - G11, CGEM, SV115T20, Meade SN8, Mod Canon 20d and T3, QSI 683 WSG,
Offline cbradshaw
« Reply #61 on: 2012 August 13 03:46:41 »
I forgot to add that I really like the script.  It is brilliant.
Charlie
Offline martin_magnan
    • Messager Céleste
« Reply #62 on: 2012 September 10 21:33:58 »
I may have found a bug in this very usefull script.
I'm imaging around RA = 0 and get this output
* Previous attempt failed - this is try #16
useScaleDifferences=false
* Reference image: Limiting to 125 brightest stars.
* Target image: Limiting to 125 brightest stars.
25 putative star pair matches.
Performing RANSAC ...
17 star pair matches in 140 RANSAC iterations.
Summary of model properties:
Inliers     : 0.680
Overlapping : 0.897
Regularity  : 0.751
Quality     : 0.729
Root mean square error:
?RMS  :  0.821 px
Average RMS error deviation:
?RMS  :  0.434 px
Peak errors:
?xmax :  1.930 px
?ymax :  0.961 px
Transformation matrix:
     -1.0123     +0.1588  +3543.5747
     -0.1616     -1.0261  +2905.7778
     +0.0000     -0.0000     +1.0000
scale    : 0.966
rotation :   -170.72°
dx       :  +3543.57 px
dy       :  +2905.78 px
202.3 s
Iteration 1, delta = 11828.053 arcsec (531.0 pixels)
Image center ...... RA: -00 27 03.143  Dec: +69 36 11.03
Resolution ........ 21.59 arcsec/pix
*** Error [000]: /Applications/PixInsight64.app/Contents/src/scripts/ImageSolver+AnnotateImage/ImageSolver.js, line 1163: Error: StarGenerator.centerRA(): numeric value out of range: -6.7631
I think the script return a negative RA value that cause an error
Martin
TEC140 / AP1200GTO / QSI583wsg - Astrodon LRGB 2 filters / Lodestar X2 Guider / Robofocus
http://www.messagerceleste.com
Offline Andres.Pozo
« Reply #63 on: 2012 September 11 01:17:45 »
Martin
Hi Martin,
are you using the last version (v1.6)?. I think that I fixed this problem some time ago. You can find it in the first post of this thread: http://pixinsight.com/forum/index.php?topic=3966.0
If you are already using the last version, I would need the image to be able of reproduce the problem.
Andrés.
    • Messager Céleste
« Reply #64 on: 2012 September 11 09:29:43 »
Hi Andres
I had a previous version (1.5.2 I think) I tought this script was updated with the PI update process. Anyway I got the last version and I have to test it tonight.
Thanks for both this script and the anotation script. They are both very valuable to me.
Martin
Offline Andres.Pozo
« Reply #65 on: 2013 December 29 12:06:18 »
I have written a detailed help file for ImageSolver. It covers the basic use of the script and what to do when there are problems.
It will be available from the update system in a few weeks. Meanwhile, I have generated a PDF with its contents that can be found in this other thread:
http://pixinsight.com/forum/index.php?topic=6535.0
Offline Harry page
« Reply #66 on: 2013 December 29 12:13:32 »
Hi There
I think we need to put you for "god status"
many ,many thanks for your hard work which you share for free  :-*
Happy new year
Harry
Harry Page
Offline cs_pixinsight
« Reply #67 on: 2014 January 22 13:29:18 »
Andres, I'm running into some rendering issues within the script windows for Image Solver and Catalog Star Generator.  I'm running Pixinsight 1.8.0 1071 on Mac OS X 10.7.5 on a MacBook Pro.
Attached are screen captures of the issues I'm seeing.
Craig
Offline Andres.Pozo
« Reply #68 on: 2014 January 23 06:30:57 »
Craig
Hi Craig,
I haven't a Mac so I can't test the scripts in OS X. However, since they work well in Windows and Linux, the problem probably is in PixInsight (or in one of the libraries it uses) and not in the scripts.
Have you tried the latest versions of the scripts distributed with PI 1.8.1?
Offline Josh Lake
« Reply #69 on: 2014 January 23 06:57:15 »
I've run into that as well, a 'pinched' field at certain resolutions (usually when showing PI on a projector). If the script window could be resized, I bet it would expand and be visible.
Craig, have you tried changing your resolution? But I agree that this issue needs to be adjusted somehow.
Offline Andres.Pozo
« Reply #70 on: 2014 January 23 07:06:56 »
What OS and PI version are you using Josh?
« Reply #71 on: 2014 January 23 07:12:52 »
I cannot reproduce this problem on any platform, including Mac OS X 10.6 and 10.8. What screen resolution do you have?
« Reply #72 on: 2014 January 23 11:46:52 »
All, I have a my laptop set to 1440 x 900.  I also have a thunderbolt display running at 2560 x 1440 as a secondary monitor.  Both show the same issue.  I have tried a resolution of 1344 x 840 on the laptop screen and 2048 x 1152 on the thunderbolt display and I still see the same rendering issues.
I'll download PI 1.8.1 when a version that will work with my OS is available and retest.
Craig
« Reply #73 on: 2014 January 23 12:01:48 »
A version for Mac OS X 10.6/10.7 is already available since yesterday, both on Software Distribution and Endor.
I have Mac OS X 10.6 and cannot reproduce this problem. Screen issues on Mac OS X are always infuriating....
« Reply #74 on: 2014 January 23 12:31:14 »
I just retested with build 1079 of PI 1.8.1 and the latest versions of the scripts.  They still render incorrectly, but Catalog Star Generator actually got worse.
Craig
