Author Topic: Image Integration crash  (Read 3640 times)
Offline dougj7
« on: 2012 February 21 07:08:54 »
The latest version with all updates still crashes during "integrating channel 1 of 3". The only option changed to the image integration process was under pixel rejection I selected  "winsorised sigma clipping". 22 .fits images from my qhy8l ccd. Using the Win32 latest version of Pixinsight with all updates installed. I reverted back to version 01.07.00.0697 and was able to successfully perform imageintegration with the same files. Not sure if this is enough information for this bug, please let me know. -Doug
Re: Image Integration crash
« Reply #1 on: 2012 February 21 07:34:14 »
What do you mean by "crashes"? What error message are you getting?
If it is an out of memory error, then you can try lowering the "Buffer Size" parameter to 8 MB or less. Your best option is of course a 64-bit version of PixInsight running on a 64-bit operating system.
Offline dougj7
« Reply #2 on: 2012 February 21 07:55:28 »
Microsoft Visual C++ Runtime error. If memory was an issue, wouldn't the previous release of pixinsight have posted the same error? My hardware hasn't changed. Windows 7 32bit, 4gig ram.
« Reply #3 on: 2012 February 21 08:24:34 »
Memory requirements tend to increase with each new version, in general.
This problem seems the same as this one:
http://pixinsight.com/forum/index.php?topic=3545.msg25044#msg25044
Try decreasing the stack size parameter in ImageIntegration and perhaps also buffer size. As a proof of concept, try setting stack size to 100 MB instead of its default value of 1024 MB. Also try seting buffer size to 4 MB instead of 16 MB.
Offline dougj7
« Reply #4 on: 2012 February 21 08:43:57 »
Thank you Juan,
reducing the buffer and stack size worked. no more crashes.
Regards, Doug
