Author Topic: Sample PixInsight LRGB Workflow  (Read 16519 times)
Offline Sean
    • My Personal Website
« on: 2012 February 20 16:44:21 »
I've documented my PI LRGB workflow in some detail, and posted it on my website: www.drakevisual.com/lrgb-processing. It's text only at this point, but I'll expand it and add some screen shots as I get the time. I hope you find it useful, and as always I welcome comments and suggestions.
Sean
Offline Jay
Re: Sample PixInsight LRGB Workflow
« Reply #1 on: 2012 February 20 23:43:01 »
Sean,
Thanks for a very informative workflow, very useful.
Jay
« Reply #2 on: 2012 February 21 07:57:38 »
Hi Sean,
I've read your tutorials on deconvolution and LRGB workflow. Nice work!
That old tutorial on deconvolution is completely outdated and obsolete. I am glad you still can find something useful in it though. When I wrote it (some thousands years ago) everything was different and we lacked a lot of resources. Now we are stronger and know more things, some of them important :)
Offline jmtanous
« Reply #3 on: 2012 February 21 16:05:21 »
I took a quick look to your LRGB tutorial. More or less I follow the same path, the only major difference is that I use pixelmath to create my master RGB image instead of the LRGB tool as you stated in step 2 of 'RGB Processing'
Thanks for the document.
Jose
Offline winch20010
« Reply #4 on: 2012 February 24 23:16:17 »
Hi Sean,
thanks for this tutorial. really useful, but a bit complicated for a noob like me ;)
will it be possible to see this process in a video ? I will really appreciate it
thanks again  :)
Offline Josh Lake
« Reply #5 on: 2012 February 25 05:26:26 »
Winch, don't panic! I recommend you watch Vicent Peris' workflow -- it's pretty similar in the broad strokes to this one, just without the linear noise reduction. I learned a ton from this video: http://www.youtube.com/watch?v=zqhLKIjGMXA&feature=related  (2 parts)
Of course, Harry's videos are also great for learning about specific tools: http://www.harrysastroshed.com/pixinsighthome.html
Sean, I was wondering about your use of MMT instead of Atrous for noise reduction. Is it just a preference or do you have reasons for doing it that way? I made a major leap from non-linear ACDNR to linear ATWT noise handling when Harry posted his video on it, and the results have been wonderful for my data. I'll look into MMT if it's a significantly different option.
Offline Sean
« Reply #6 on: 2012 February 25 10:56:52 »
Winch,
I'll repeat what jlake has said - check out Harry's videos as a good starting point - that's how I learned my way around. Also, Vicent's workflow video is very good, and I do follow the same general path. I have tried to add more detail about some of the decision points than Vicent had time for in the video. When I get a chance, I'll add some screenshots to my workflow.
Jlake,
I've also used Atrous with good success, but have recently started using MMT more often. I feel like I have a little greater control over the noise reduction, but it could also be a result of the kinds of images I've been working on lately. If I get a chance, I'll try to do a direct comparison between the 2 on the same image.
Thanks for the comments,
Sean
Offline starhopper
    • starhopper
« Reply #7 on: 2012 October 18 12:37:36 »
Hello Yose
can you tell why you use Pixel Math instead of the LRGB Tool?
Thomas
Thomas Jäger
https://www.starhopper.eu
12"f/3.8 & 8"f/2.9 Astrograph
SBIG STL11000M, Moravian G2 8300
Vixen Atlux Mount, Skywatcher AZ-EQ6 GT
Skywatcher Esprit 100/550
