Hi all,
I'm working with three images and searching to do HDR composition in many flavours. I for sure made an error with HDRComposition. I tried every sequence (higher -> lower, lower->higher, Automatic Exposure evaluation checked/unchecked) but everytime I obtain the "shorter" image with a lighter stain into. I do expect most of the higher image with zones of the shorter into overexposed zones and some sort of averaging of these zones borders. Am I wrong?
So I tried also with GradientHDRComposition. Always OutOfMenory after 2/3 seconds. The same if I reduce the images deepness to 32bit float and also 16 bit unsigned. I've 4GB RAM, no other processes running and when the process goes out of memory the PI process RAM consumption is lower then 500MB (RAM+Virtual memory). Ok I'm running 32 bits but this is too much! If this is the case, please specify in requirements that a 64bits OS is mandatory...
PI 1.7.5, all updates done, Windows XP 32bit, 4GB RAM.
Thank you for any hint....
Federico
