Author Topic: PI Freezed when savin a proyect  (Read 4091 times)
Offline gvanhau
« on: 2012 February 04 19:37:43 »
Hello
I was saving my new project.
After an hour of inactivity (watching with task manager and recource monitor) I finally had to kill PI.
It created the data directory whit 28Gb data on it  but no xosm file.
Is there a way to recover the project?
Platform is win64 8G ram 4 core Phenom.
Regards
Geert
Geert Vanhauwaert
Re: PI Freezed when savin a proyect
« Reply #1 on: 2012 February 05 04:05:35 »
I had something like this when I ran out of disk space. Is your disk full?
Offline gvanhau
« Reply #2 on: 2012 February 05 09:24:06 »
I still have 50Gb free.
Anyway, do you know why a proyect uses such huge amount of space?
Regards
Geert
Geert Vanhauwaert
« Reply #3 on: 2012 February 05 11:41:41 »
...Anyway, do you know why a proyect uses such huge amount of space?
No idea. Maybe a bug, maybe a large history??
« Reply #4 on: 2012 February 05 15:49:23 »
it's saving all the images that comprise the history of each window. so that can take loads and loads of disk space.
« Reply #5 on: 2012 February 05 16:00:44 »
by the way, because of this, whenever i use the MaskedStretch script i will usually clone the result, then undo all the way back to before i did the masked stretch on the original image, and then do something else, like inverting it or some other junk operation which i then undo.
that will clear out all the history associated with the masked stretch, which can be 50-100 images depending on how you run the script.
Offline gvanhau
« Reply #6 on: 2012 February 05 17:06:19 »
thanks pfile
I'll take this in account, because I use this script, and there is no disk that can hold those proyects.
may be the right solution is to execute the script on a clone, then copy the clone back to the original image and delete the clone....
regards
Geert
Geert Vanhauwaert
« Reply #7 on: 2012 February 06 01:28:03 »
I think this should be considered to be a bug in the MaskedStretch script. It does not make sense to store the history for each single step. If you agree, please submit a report in the bugreports/wishlist section of the forum.
Offline Andres.Pozo
« Reply #8 on: 2012 February 06 02:14:38 »
It is not a bug of the script. The problem is in the histogram transformation. In this tool the history/undo information can not be disabled when it is used with a mask.
« Reply #9 on: 2012 February 06 02:15:47 »
So its an improvement request for Juan?
