Author Topic: Combining Bias frames  (Read 4415 times)
Offline Komet
« on: 2012 January 15 03:24:19 »
Hello all ....
I am having problems combining bias frames in PI. Each sub frame has an average background of around 669 and yet when combined in PI (using Average/ No normalization) I get a master bias with a background of around 33000. This of course is useless.
Any pointers please about where I am going wrong?
Cheers
Mick
Offline vicent_peris
    • http://www.astrofoto.es/
Re: Combining Bias frames
« Reply #1 on: 2012 January 15 05:40:05 »
Hi Mick,
Be sure you don't have a flat frame inside your bias image set... This happened to me more than one time.
Vicent.
Offline oldwexi
    • Astronomy Pages G.W.
« Reply #2 on: 2012 January 15 08:16:55 »
Hi Mick!
Could be a FITS format problem. Comes usually with Fits-files from Maxim...
Have a look here for one of the many solutions:
http://pixinsight.com/forum/index.php?topic=3597.msg24669#msg24669
Aloha
Gerald
« Reply #3 on: 2012 January 15 09:00:32 »
It seems that the data has been stored as signed integer, or something like that... 65536/2 + 669 = 33437. That explains  the values you are reading.
To fix that, make sure that you are saving the bias frames with the appropriate format.
Another workaround: Use PixelMath to correct the value of the master bias. Just subtract 0.5 to the target image (expression: "$T-0.5"), disabling the rescale option.
