Author Topic: imageintegration close the program / imageintegration me cierra el programa  (Read 3415 times)
Offline David
hello
do not know if this is the right place
I am integrating 66 RAW images and the program closed after the noise evaluation, when you begin to integrate channel 1 - 0-X% 500pix
at first I thought it could be a problem of PC, windows was giving errors so i reinstalling the OS and all the same, I tried on another PC and the same.
I tried to integrate 4 pictures and works ok, plus I made ??before this darks and bias without problem.
know what may be the cause?
previously it had already built up to 70 images ...
thanks for your time
hola
no se si este es el lugar correcto
estoy integrando 66 imagenes RAW y el programa se cierra despues del noise evaluation, cuando empieza a integrar canal 1 - 0-500pix X%
en un primer momento pense que podia ser problema de PC, windows estaba dando errores asi que reinstale el SO y todo igual, he probado en otro PC e igual.
he probado integrar 4 imagenes y funciona ok, ademas antes de esto he integrado darks y bias sin problema.
conocen cual puede ser la causa?
anteriormente ya habia integrado hasta 70 imagenes...
gracias por su tiempo
Offline Andres.Pozo
If you are using a 32 bit version, you should read this message:
http://pixinsight.com/forum/index.php?topic=3445.msg23772#msg23772
« Last Edit: 2012 January 12 06:32:50 by Andres.Pozo »
Offline David
thank you very much Andres.
is the same problem. Unfortunately my problem is to find my language posts
because the problem is identical, the partners have the same questions I have.
with the last version, I managed to integrate days ago, why today no I can?
now I'm trying buffer size 0, then prove buffer size 4, when finished this process I installing it version 1.6 to see if I have this problem.
I know my computer is obsolete, but it will change only when there is no choice but.
I tell them the news about it, and thank you very much
muchas gracias Andres.
es el mismo problema. por desgracia mi problema para encontrar posts es mi idioma
pues el problema es identico, los compañeros han tenido las mismas preguntas que tengo yo.
si con la ultima version, dias atras he logrado integrar, por que ahora no si todo sigue igual.
ahora estoy probando bufer size 0, despues probaré bufer size 4, cuando finalice instalaré version 1.6 a ver si no tengo este problema.
ya se que mi ordenador es algo obsoleto, pero solo lo cambiaré cuando no quede mas remedio
les cuento las novedades al respecto, y muchas gracias
Offline David
hello
ok integrated with buffer size 4, my habit was to go down to 8.
so  I can not change the PC until it explote.
thank you very much for everything
