Author Topic: Combining unbinned data with binned data, same channel  (Read 3985 times)
Offline ManuelJ
    • ManuelJ Photography
« on: 2012 January 09 04:06:26 »
I'm thinking about capturing the same data binned and unbinned, to get nice SNR in the faint nebulosity without erasing the detail in the good SNR data. The only thing I can think of it's a SNR mask, but that doesn't work well, because the stars will get bigger because of the unbinned image.
A star mask will do the trick, but creating a perfect star mask is something outside my knowledge.
Any ideas?.
Manuel.
Re: Combining unbinned data with binned data, same channel
« Reply #1 on: 2012 January 09 05:24:55 »
You may try a wavelets decomposition. In a nutshell, replace the first two layers of the binned image (upsampled to the unbinned size) with the first two layers of the other image.
How to do that:
- Delete the first two layers on the binned image (previously upsampled and registered with the unbinned image).
- Clone the unbinned image, and delete the first two layers on the cloned image.
- Apply this PixelMath expression to the clone: "unbinned - clone + 0.5". Disable rescaling, and replace the image.
This will create a high pass image, where you have only the information of the first two layers. Now we have to add this data to the binned image.
- PixelMath: "binned + clone". Enable rescaling.
You may try also using a mask derived from the luminance, to target the high SNR zone more, and thus preventing too much noise to contaminate your background. I would use a blured luminance as mask, with the histogram adjusted.
Offline ManuelJ
« Reply #2 on: 2012 January 10 02:31:46 »
Good point, Carlos. I'll try that.
Manuel.
