Author Topic: Error during Image Integration (and request to contact You)  (Read 4507 times)
Offline federico
  • A brilliant future behind
    • Business site
PI 1.7.4 continues to give me troubles during image integration.
16 frames (integer 32 bits) from a Canon 450d. I've tried with and without noise evaluation (this saved me in the past) but no luck.
This time, instead of the usual "Out of Memory", a different exception appeared, together with the invitaton to contact the support team...and here I am. See the attached image, it describes well the situition.
PI 1.7.4 (just upgraded) on Win XP, 4 GB RAM.
Happy Christmas
Federico
Re: Error during Image Integration (and request to contact You)
« Reply #1 on: 2011 December 29 10:56:38 »
Hi Federico,
Take a look at the following thread:
http://pixinsight.com/forum/index.php?topic=3445.msg23756#msg23756
where a similar problem has been reported recently. As noted in that thread, the only good solution to this problem is using a 64-bit operating system and a 64-bit version of PixInsight. The workaround that you can use is decreasing the value of the buffer size and stack size parameters. For example, try setting buffer size to 4 or 2 MB. Hope this helps.
Offline federico
    • Business site
« Reply #2 on: 2011 December 30 00:24:13 »
I tried the solution you suggest (I 've found it by myself reading the small hints in ImageIntegration. Very helpful, keep on them!) and I got success. My god, changing again PC and OS, @!#@!!!!
But sooner or later....
Federico
PS. You declare in release notes that GradientDomain Module is now standard...but I can't find it anywhere. What should I do to display it?
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
« Reply #3 on: 2011 December 30 09:55:41 »
If is not visible inside 'GradientDomain' node, try to do a 'search' of modules (right click over background, Install Modules..., button 'Search', select and install)
Hope this help,
Enzo.
Offline federico
    • Business site
« Reply #4 on: 2011 December 30 10:11:25 »
Found!
Grazie enzo
Federico
