Author Topic: PixInsight 1.7.4 Released  (Read 16440 times)
« on: 2011 December 28 17:20:17 »
Hi all,
Today we have released a new version of PixInsight: 1.7.4. This is a transitional version to stabilize the platform in preparation to more important releases that we'll see in 2012.
Along with lots of bug fixes and stability improvements, PixInsight 1.7.4 introduces the following main features:
Improved Mac OS X / Cocoa 64-bit version
With this release we have made big efforts to achieve a fully stable 64-bit version of PixInsight for the Mac. Most of the previous problems should now be fixed. This has been possible thanks to the new Qt 4.8.0 version, which---at last---fixes most of the bugs that have been serious obstacles until now. Not all Qt bugs have been fixed, but we have managed to work around almost all remaining problems with our own platform-specific code.
As far as we have tested it, only two problems remain to be fixed in the 64-bit version of PixInsight for Mac OS X:
- The application loses the keyboard focus sporadically. Despite this sounds somewhat 'dramatic', it is actually a very minor problem in practice. Sometimes the keyboard ceases to work on image windows (e.g. using the space bar key to activate the pan mode) and on the Process Console window (command line). Fortunately, when this happens all tool windows continue working normally, so you can always use the keyboard to enter numeric parameter values, file paths, etc. If this happens, open the Process Explorer, extend it and click on the documentation browser's URL field. This simple action usually fixes the problem.
- Moving items---especially icons---around the workspace is a bit slow (performance issue). The same happens with the readout preview when you click on an image.
Other than these issues, the 64-bit version seems to work extremely well on Mac OS X, at least with our machines. In addition, the new version should show some love to OS X Lion.
The current 32-bit (Carbon-based) version of PixInsight could be the last one if we manage to fix all of these problems completely in the next release. As Mac OS X is a native 64-bit operating system (since 10.6 Snow Leopard), the only reason to maintain a 32-bit version has been persistence of problems in the 64-bit version. So if PixInsight/Cocoa becomes fully stable, we can say good-bye (and thanks) to PixInsight/Carbon very soon. Everything indicates that this will be the case for PixInsight 1.8.0.
New GUI Features
New Copy View Zoom function. When two views have the same geometry, you can drag one of the view selectors to the other one to copy the current zoom factor and scroll position. This is very useful to compare images and previews.
New Fast View Navigation function. Press the right mouse button and keep it pressed while you move the cursor over the view selectors of an image window. This selects the view under the cursor without additional clicks.
New Quick View Select function. When you are dragging a process icon, a process instance or a view selector, simply hit the Shift key to bring the image under the cursor to the top of the windows stack on the current workspace.
The Escape key now works as the Pause/Abort button. You can hit Esc in the middle of a long process to pause and cancel it.
Improved AutoHide windows. AutoHide windows (Process Explorer, etc.) now are hidden automatically when you move the cursor outside them. Clicking on the workspace or on a tool window is no longer necessary to hide the Process Explorer.
Script Editor's syntax highlighting updated to match the latest version of the PIDoc document definition language.
New Compile PIDoc Document menu action available on Script Editor. You no longer have to run the PIDoc compiler script while you are authoring documentation; a simple menu selection does the work.
New Default Favorite Process Collection
The previous default favorite process collection was seriously outdated. We have defined a new one with the following processes:
      ATrousWaveletTransform
      BackgroundNeutralization
      ColorCalibration
      CurvesTransformation
      Deconvolution
      DynamicBackgroundExtraction
      DynamicCrop
      FastRotation
      HDRMultiscaleTransform
      HistogramTransformation
      MorphologicalTransformation
      MultiscaleMedianTransform
      PixelMath
      ProcessContainer
      Resample
      RGBWorkingSpace
      SampleFormatConversion
      ScreenTransferFunction
      StarMask
      Statistics
The ACDNR process has been excluded because it will be declared obsolete, probably in the next version. Unless you have defined your ownn favorite process collections, we encourage you to test the new default one by right-clicking on one item of the Process Explorer window and selecting 'Set Default Favorite Process Collection'.
New Standard GradientDomain Module
With this version we have included Georg Viehoever's GradientDomain module in the set of standard modules distributed with the PixInsight Core application. All existing projects and process icons of these processes will continue working normally.
We hope you like it. Happy new year to everybody!
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
Re: PixInsight 1.7.4 Released
« Reply #1 on: 2011 December 28 17:35:09 »
Yes! I love it! :)
And I like all the new GUI features! Thanks!!
Enzo.
Offline Josh Lake
« Reply #2 on: 2011 December 28 18:02:18 »
Fantastic news, especially for us Mac PI users who have sometimes been unnerved by the quirky behavior of the 64-bit version. Thank you!
I'm very interested in this one but can't seem to make it work. By 'view selector', do you mean the top bar, one of the viewing tools, or something else?
« Reply #3 on: 2011 December 28 18:13:03 »
ACDNR will be declared obsolete? Seriously? That's sort of like stepping into my workshop and telling me I can't use my hammer anymore. It won't make you terribly popular. Please reconsider. Well, you can declare it obsolete if you must as long as it remains available and maintained.
    • Astronomí­a Sur
« Reply #4 on: 2011 December 28 18:51:14 »
Drag the image vertical tab to another one (with same geometry). The dragged icon change, you can drop them, and voilà. ;)
Offline Yuriy Toropin
« Reply #5 on: 2011 December 29 00:39:11 »
Looks like distributive of the
   PixInsight Core for Windows (x86_64 - 64-bit)
   Core version 01.07.04.0759 (commercial)
has been placed yesterday (2011 Dec 28 19:33:30) to the PixInsight Software Distribution Interface
and it has not been deployed via automatic update system yet...
What is the correct installation procedure for it?
Should it be installed manually after manual uninstall of the recently installed version?...
Thanks a lot,
   Yuriy
Offline bitli
« Reply #6 on: 2011 December 29 01:47:52 »
Thank you very much, updated without a problem.  I am very happy that we get (very slowly)  additional documentation.  For me it was a major issue so I hope this effort will not be stopped. I am persuaded that the documentatio n(especially the very well written documentation we see) could be a great selling point of PI.
About 'acdnr', it would be nice if the annoucement of its obsolecence could be complemented by an information as 'because now the process XYZ is better' or 'it is integrated in...' or 'noise is now illegal  :)' .  There is surely a reason, however I do not follow all the threads so I do not know what is wrong with acdnr (no need to re-explain here, but a pointer would be nice)
Happy new year
 -- bitli
« Reply #7 on: 2011 December 29 01:57:20 »
ACDNR won't be obsoleted until we release a new noise reduction tool to replace it. ACDNR is rather old (2006) and has serious limitations. We have now much better techniques under control and much more knowledge and experience. The new tool will be based mainly on anisotropic diffusion and wavelets, and should work equally well with linear and nonlinear data. An initial version might be ready during Q1 2012 (in PI's relativistic time scale).
Despite we'll release a new NR tool, be sure ACDNR will remain available in PixInsight for a long time. Too many existing data and projects depend on it.
« Reply #8 on: 2011 December 29 02:04:45 »
Hi Yuriy. You should have received an announcement email yesterday, where we note that this release won't be distributed via updates. You have to uninstall your current version, download the new installation package from software distribution, and install it manually. We also recommend you perform a full configuration reset (select the 'Reset PixInsight Settings' option from the Start menu). Should you have customized preferences, don't forget to save a Preferences icon before you reset.
« Reply #9 on: 2011 December 29 02:19:17 »
... By 'view selector', do you mean the top bar, one of the viewing tools, or something else?
View selectors are vertical tabs with view identifiers, located at the left edge of each image window. The vertical areas where view selectors are normally docked are view selector trays. You can perform several actions with view selectors:
- Dragging a view selector to the workspace duplicates it as a new image window.
- Drag a view selector to its parent tray to create a new preview with the same geometry.
- Drag a main view selector to another window's selector tray to activate it as a mask for the target image. Both images must be mask-compatible (if T is target image and M is mask: T is not a mask for M, T and M must have same dimensions, M is grayscale, or M is RGB only if T is RGB).
- Drag a preview selector to another window's selector tray to create a new preview with the same geometry (this is called transporting a preview).
- Drag a view selector to another view selector to copy its zoom ratio and scroll position (new function in 1.7.4). Both views must have the same geometry.
- Drag a view selector to a workspace selector (small gray square icons at the bottom control bar that allow you to select workspaces) to create a new image on a different workspace.
- Double-click a view selector to change the view's identifier.
- Ctrl+Double-click a preview selector to change its properties.
« Reply #10 on: 2011 December 29 02:21:36 »
Thanks to everybody for your nice words and encouragement. I wish you all the best for 2012, including lots of clear nights with perfect seeing. Enjoy! :)
« Reply #11 on: 2011 December 29 08:30:28 »
Thanks Juan for the additional information regarding ACDNR. It may have limitations but it gives excellent results without much effort (ie. most parameters the same)  and that's worth a lot to me. Looking forward to the new process.
Offline Oleg Astro
  • Albufeira, Portugal
    • Ubuntu Astronomy 16.04
« Reply #12 on: 2011 December 30 10:01:15 »
Hola muchachos!
Don't understand anything...  :-[
The previous core worked with a big image for ~90Mpx in the mosaic's mode, but the new one doesn't want to work: it reports that there's not enough memory.
OS: Ubuntu 11.04 32-bit
RAM:  5GB
P.S. I launched a version with the previous "june's" core (v. 01.07.00.0697-20110601): the programm works with an image for ~98Mpc in the mosaic's mode.
The memory if loaded a bit more than on a half.
« Reply #13 on: 2011 December 30 10:19:35 »
You should probably post bug reports in the appropriate forum rather than mixing them into this thread.
Offline alejandromeira
« Reply #14 on: 2011 December 31 00:08:25 »
Hi! I've download the new version to the desktop and I've uninstall the old version, then simply I've clicking the new .exe file and it's allright, very very easy installation. Apperance seems the same  that in the older version, that's ok.
