Hi Juan,
I'm not sure why this is, but updates fail for me with using the default settings. The default path for downloads is C:/Users/Eddie/AppData/Local/Temp
The Package download succeeds, but when PI is closed and update attempted, the update fails reporting "Can't find required components". Then PI appears to shut down, but is actually still running and needs to be killed from the task manager.
I suspect a permissions issue on the path, but I don't know why as PI is running as admin and the folder is owned by me... and the packages were successfuly downloaded to the path.
I'm wondering, when PI restarts, is it running with the same permissions as the instance that called it ?
There is a solution.. If I change the download path to somewhere else, it all works properly. I had this problem with the previous version as well and fixed it this way, but as I just erased the old PI settings for the latest version, it has just happened again and I thought I'd better let you know before I forget all about it...again...
