Author Topic: California Nebula and Sh2-240  (Read 6949 times)
Offline twade
« on: 2007 October 14 18:59:05 »
To all,
All images were taken with the FLI ProLine 16803 through an Astrodon H-alpha filter.
The California Nebula is a composite of four 30-minute exposures taken through a Pentax 67 300mm lens at F/4.0.
2400x2400:
   http://tinyurl.com/2vnrux
1600x1600:
   http://tinyurl.com/3aef25
Sh2-240 or Simeis 147 is a composite of three 30-minute exposures taken with the same lens mentioned above.  I planned four images, but the last image wigged out and was unuseable.
2400x2400:
   http://tinyurl.com/2lt7sq
1600x1600:
   http://tinyurl.com/2v5k3k
I'm hoping I'll get a few more clear skies this Fall to add more data to each.  Most of the processing was done in PixInsight Standard (i.e. exponential stretching and noise reduction).
Wade
« Reply #1 on: 2007 October 16 04:10:32 »
Hi Wade,
You are terrific with that CCD camera. Both images show extremely dim objects, even some that I haven't seen before. Simeis 147 definitely asks for more signal, though.
The resolution and dynamics that you are achieving are awesome. I recommend you to perform the entire processing in a 32-bit format.
Are you thinking on adding color soon? Anyway, I don't see a real need to do so, from an aesthetic point of view. These Ha images are outstanding as they are, and I think you have a vast path to explore with your current hardware.
A points that you have to work on is applying some detail improvement. In particular, the Simeis 147 image is a perfect candidate for deconvolution and/or wavelets processing. Not an easy target, indeed, but it needs improvement at small and medium scales, in my opinion.
Congratulations on two fantastic images.
Offline GABRI 9555
    • http://www.pbase.com/gabriel_medina_9555/universe_in_narrowband
« Reply #2 on: 2007 October 16 04:30:29 »
hi Thomas,
good job , congratulations on two beautiful images.
gabri
saludos / regard
Offline twade
« Reply #3 on: 2007 October 16 07:10:15 »
Juan and Gabri,
Thanks!
Quote from: "Juan Conejero"
I'm still in the learning process so things can only get better.  :D   It definitely helps to have an extremely dark sky too.
It's too bad the fourth shot was unuseable.  I definitely plan on imaging this thing for at least six hours.  I just hope Mother Nature cooperates.  She usually doesn't this time of year.  :cry:
As you can see, I'm doing more and more processing in PixInsight Standard so I will definitely be exploring the 32-bit format realm in the near future.
I'll probably do a little color next year; however, I'm having so much fun with H-alpha, it's going to be hard to drive me away from it.  :)
Yes, as you've noticed, I haven't done any "sharpening" processes on the images.  I definitely plan on doing some deconvolution or wavelet processing in the future.
Wade
Offline Jordi Gallego
« Reply #4 on: 2007 October 16 10:47:44 »
Wonderful images wade, I like specially  Simeis 147. You and your camera are doing a really a nice job :wink:
Regards
Jordi
Jordi Gallego
www.astrophoto.es
Offline Jack Harvey
Good Work
« Reply #5 on: 2007 October 19 14:33:00 »
Very nicely done on all accounts.  Now for color<G>
Jack Harvey, PTeam Member
Offline Maxi
  • Barcelona / EspaƱa - Spain
    • http://www.astromodelismo.es/index.htm
« Reply #6 on: 2007 October 20 00:31:11 »
They are a wonderful photographs and especially this Simeis 147.
Yo, the SH-2, which are nebulae soil draw in a large field of my shots and when possible, I want to begin conducting intakes has primary focus and make some of these.
Sincerely, Maxi
