Author Topic: Calibration and align batch operations  (Read 214552 times)
Offline Harry page
Re: Calibration and align batch operations
« Reply #120 on: 2012 March 19 12:59:56 »
I get this error  :-\
PI calibrates the files and saves them ( good so far ) but falls over at the registration  :o
Harry
Harry Page
Offline Harry page
« Reply #121 on: 2012 March 19 13:02:26 »
Bit closer
Harry
Harry Page
Offline Harry page
« Reply #122 on: 2012 March 19 14:46:17 »
This is very very close  :-*
Can we make the script remember the last setting when closed i.e what files were selected , better than starting from scratch when redoing the same files
Harry
Harry Page
« Reply #123 on: 2012 March 19 14:47:57 »
Harry, create a process instance (blue triangle) to save the settings.
Offline Harry page
« Reply #124 on: 2012 March 19 14:52:37 »
Yes I did see this  :laugh: , perhapes a personal thing I like simple to reuse not a game killer though
Harry
Harry Page
« Reply #125 on: 2012 March 19 17:03:06 »
Here is version 0.2 of the Batch Preprocessing script. News:
* Added preliminary support for CFA mosaiced images. OSC camera users should have no problems to calibrate and align their images with the script as it is now. DSLR camera users still need to convert their camera raw frames (CR2, NEF, etc.) into FITS files with the standard BatchFormatConversion script before using Batch Preprocessing. Only bias and dark frames need to be converted; flat and light frames will work in their original camera format without problems. These limitations should be removed in the next versions of the script.
* Added new GUI controls to implement CFA support.
* A new check box to enable/disable dark frame optimization (applied to calibration of flat and light frames).
* Published under PCL v1.0 license.
Please test it and report any errors here. Enjoy!
Offline vicent_peris
    • http://www.astrofoto.es/
« Reply #126 on: 2012 March 19 18:16:27 »
Could it be possible to add a crop option to this script? Sometimes it's better to crop the borders of the image just after the calibration process. For instance, if you use an overscan enabled camera, the overscan areas can be extremely noisy after calibration. This can affect the registration and integration process.
Vicent.
Offline mmirot
« Reply #127 on: 2012 March 19 19:10:07 »
I found no defects using add images as long as I started with a dark frame set of the same exposure.
The script created a usable dark master that worked subsequent operations. Other Master are fine too.
Wow...Lots of nice improvements.!
Calibration goes 3x faster without the cache for integration too. Can that work with registration?
I tried to use a single long dark frame selected with optimize checked but the calibration results were incorrect.
 I usually use a set of equal exposure darks so perhaps I am not doing this correctly?
Max
Offline mmirot
« Reply #128 on: 2012 March 19 19:17:12 »
I would add cosmetic correction to the wish list.
I have annoying hot column.  It would be nice to fix it prior to registration and integration.
Max
« Reply #129 on: 2012 March 19 23:12:37 »
...Yes I did see this  :laugh: , perhapes a personal thing I like simple to reuse not a game killer though
I agree: the way, for instance,the AnnotationScript keeps the settings from a previous run is also very convenient. Maybe having both would combine the best from both worlds...
Offline mmirot
« Reply #130 on: 2012 March 20 00:29:46 »
A prior version preserved both settings and paths . Juan will add this soon ... Trust me ;)
Max
Offline kwiechen
« Reply #131 on: 2012 March 20 00:45:14 »
Hi Juan,
looks great! It would have lasted a very very long time for me to bring this into a comparable state with tight integration into the PI system.
I have played a little bit with v0.1.
1) The script needs all file slots to be filled and a reference image selected. It should be possible to run the script with calibration frames only
2) The reference image was selectable simply by clicking in the file list in 007h
3) Checking of the masterframe checkboxes select only the first frame in the list as a master. The script fails therefore to calibrate and align with predefined masters (for example with 4 channels LRGB).
I will test v02 with 'fresh' data as soon as possible.
Kai
Offline Harry page
« Reply #132 on: 2012 March 20 01:41:13 »
A save masters check box would be good , to save any newley created master bias / darks / flats for future use  :-*
Harry
Harry Page
« Reply #133 on: 2012 March 20 03:16:32 »
Hi Kai,
Glad you like it.
The script requires you to specify a registration reference image only if the 'Calibrate only' checkbox is unchecked. If you check it, then no registration reference is (should be) required.
By 'all file slots filled' what do you mean besides the reference image?
It is selectable in 0.1, too, by double clicking one of the light frames. A single click is too prone to mistakes IMO, and we probably will implement more functionality associated with clicking frame items on the treebox structures.
If the L, R, G and B images have the correct filter identified in their FITS headers, there should be no problem. Can you verify this?.
Of course we have to improve master frame management. How about an option to manually specify a filter for each frame? In this way we'd remove another FITS header dependence, and the script would be more flexible.
Great. We need lots of tests with different data samples to make this script 100% robust.
« Reply #134 on: 2012 March 20 03:20:16 »
Masters are generated during script execution and stored on the 'master' subdirectory of the root output directory.
