Author Topic: Canon DSLR: flaming nebula IC405 with 12nm H-alpha bandwith  (Read 3588 times)
Offline Christoph Puetz
    • Fotos
Dear PI Users,
here is another feed for the DSLR Users.
6"/1100mm Starfire APO refractor with 0.8x Reducer/Flattener.
Canon EOS 450d, modified
70 exposures x 210 sec, 1600 ASA and Astronomik 12nm H-alpha Filter clip filter system-
-> 4 hours exposure time.
20 Darkframes
The images was processed as a "real" color image with full RGB debayering (not only the R channel).
HDR Medium Transformation helped to reduce noise and enhance some details.
Maybe I will add full colour frames later ..... to get a ha-RGB image.
Any feedback is welcome.
http://www.ccdsky.eu/Astronomy/slides/f-ic405_h-alpha.html
or
http://www.flickr.com/photos/cpfoto1964/6334214491/in/pool-387956@N23/
(with astrometry results.
Kind regards,
      Christoph
Canon EOS 500d,
PixInsight, PHD-Guiding
private URL: www.ccdsky.eu
Offline Lex
  • We do it at night...
Re: Canon DSLR: flaming nebula IC405 with 12nm H-alpha bandwith
« Reply #1 on: 2011 November 13 01:08:20 »
Christophe,
So this is just Ha Data? The picture is a bit dark IMO and the stars come out with a red touch..
So if it is only Ha this would explain it...
Clear Skies!!
Lex
    • Fotos
« Reply #2 on: 2011 November 13 04:36:00 »
Hi Lex,
yes - it is indeed only H-alpha light, processed like a regular image. I wondered myself, that this could look
this way. You are right, it is a bit dark - but it supresses some chromatic noise as the "green and blue pixels"
in the Bayer Matrix are not "used" (??).
Maybe I could try to switch the Canon into "Gray Mode" and see how this would affect something.
I saw in your appendix that you observe near Luxembourg ? Well this is just near my observation site !!!
Please have a look at this site :
http://www.sternwarte-peterberg.de/sternwarte/koordinaten.html
Astronomically speaking  - this is "just around the corner" !!!  :D
So if you are interested in a visit - you are invited, we sometimes have visitors from Luxembourg.
Kind regards,
      Christoph
Canon EOS 500d,
Offline Lex
« Reply #3 on: 2011 November 13 06:12:38 »
Yes indeed switching the canon to mono could help, there could be some hidden metadata telling that it is color version.. So PI would recognize it as greytone image?
I already noticed your site lies only a Katzensprung weit weg  ;D
Why not, i would be glad to come over for a visit and exchange some astro tipps  :P
Clear Skies!!
Lex
« Reply #4 on: 2011 November 13 06:39:47 »
It may be an issue regarding connection. I tried the same monitor using the VGA connection and is less detailed and darker to DVI connection. Attached two screen shots.
In DVI connection I can see traces of nebulosity that are completely lost with VGA
Saludos. Alejandro.
« Reply #5 on: 2011 November 14 09:44:22 »
i don't know if this is a good idea. the camera might try to compute the luminance of the image and mix in low-SNR blue and green pixels with your high-SNR red pixels.
also i don't know if you can calibrate a canon grey image because if it is debayered and processed in the camera, the original raw data is destroyed...
